Have you figured out how much you want to raise it? I don't think it would be hard at all to modify the factory mounts to accommodate just about what ever height adjustment you need.
http://i245.photobucket.com/albums/gg53/jdavenport6/b-25011.jpg
just put a set of airshocks under it.till u figure out which way to go!
Just a bit of info for you guys, I used to build street rods a "while" back using Mistake II front suspensions. The easy way to cut coil springs is to submerse them in a bucket of water, where the water is just below the where you wish to cut. Use a air operated cut off grinder. The heat doesn't transfer down the coils, so you don't lose the tensile strength. Just a suggestion from an old hot rodder.
Capt_Jack thanked for this post
I think the caltracs use the rear sec of leaf for spring/height call them and ask how much for diff rear sec.
I know this has been a long time, but I can give you the correct answer to the problem. I got the numbers off the old mono leafs. I called Caltrac and told him how much higher I wanted to go, and he sold me new back halves to the existing mono leafs. They were half the price of a whole new set and raised me up beautifully. I spent $189 and got the stance I wanted. Life is good.
That is great news!! Good for both you and them.
69 Swinger 340
Soon to be 69 426 Dart
80 Crew Cab gas hawg
01 DIESEL Hauler
Bailey, Colorado
The Mr Gasket shackles will work also. I have used them before to raise the back some. They have about 5 holes in them and what I did is find the hole that raised it about an inch. Then cut the shackle off just below the hole and paint them black. That way they look stock and you dont have 4 inches of shackle hanging down below the rear of the spring. I hate when I see long shackles hanging down below the spring in the rear of a car. Ron
My car , 63 Sport Fury Max Wedge wanna be pump gas street car......10.76 @ 124.49 ! !
