I'm building a street hot rod (street/strip car)68 Dodge dart. I have all the suspension complete (coil overs all the way around, 4 link, rack and pinion steering, built 727 manual reverse valve body, 9.5" converter, custom stainless 2" stepped headers, 325/50/15 Mt drag radials, 2005 truck ECU, 15 gal fuel cell with eliminator fuel pump, wilwoods on all 4 corners)
AJ supplied complete 6.1 from top to bottom
Dave Webber supplied 6.1 ported heads, 625 PAC springs, retainers, push rods, cometic .051 gaskets, custom 230/239 603 lift on a 113, forged drop in pistons with rings.
Edelbrock E-force supercharger running a 9-10 lbs
I have not been happier with AJ and Webber on this build.. Popeyes Hemi (Jeff) will help me do the pistons and cam next wk... I'm looking to have it tuned by mid April.. Not sure what it's gonna run nor do I really care.. I'm sure it will get in the low 10's possibly 9's if I can get the bugs worked out. Hoping to go hang out with u guys at some events and run the local test and tune.. and most importantly beat up on ujokin! lol
With 10lbs of boost I hope to be over the 625-650 rwhp range.. thoughts?
68 Dart
Gen 3 Hemi
Kenne Bell S/C 10lbs boost
Full weight
Tubular K fram , rack and pinion steering, coil overs
custom tri 4 link, 3.50 gears, ford 9", detroit locker, 325/50/25 MT drag radials
sub fram connectors, 8.50 molly cage..
If I get 9.80 I'd be super happy!
Jason
68 Dart
Gen 3 Hemi
Full weight
