Oil pressure gauge
BigBlockDart.com is the premier Dodge Dart forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
+ Reply to Thread
Results 1 to 5 of 5
Thread: Oil pressure gauge
  1. #1
    Newb rtse440's Avatar
    Join Date
    Dec 2008
    Location
    Mechanicsville Va
    Posts
    13
    Post Thanks / Like
    Oil pressure gauge
    So I'm started putting my 68, 383 GTS back to original. Question, did Darts come with only a low pressure Oil Light or could you get a Oil pressure gauge in the gauge cluster? Looking at the service manual it only shows a light.
    Mark
  2. Remove Advertisements
    BigBlockDart.com
    Advertisements
  3. #2
    Super Moderator bremereric's Avatar
    Join Date
    Dec 2009
    Location
    Tomball, TX USA
    Posts
    3,888
    Post Thanks / Like
    If you have the cheapo cluster then all you have is the idiot light. If you car had the rallye gauges then you most likely have a guage. I would just add a mechanical oil pressure guage and you could hide it in the glove box.
    Eric Bremer
    Tomball TX 77375
    1968 Dodge Dart 440 Big Block, Edelbrock Performer RPM Heads, Performer RPM intake, Holley 770 CFM Street Avenger, .541/.538 lift hydraulic roller cam, Harland Sharp 1.6 Ratio Roller Rockers..Crane Roller lifters..580 Final lift, MSD pro-billet distributor, MSD ignition, 355 Auburn Suregrip 8 3/4 rear end.
    1977 Dodge Aspen R/T...318...4 speed tranny with 355 gears in a 8 1/4" rear.
  4. #3
    Join Date
    Dec 2008
    Location
    Mechanicsville Va
    Posts
    13
    Post Thanks / Like
    So, Dart's had a option of a rally gauge cluster, I will start looking through the boxes that came with my Dart and see if there is one . Previous owner installed a restored gauge cluster.
  5. #4
    Super Moderator chryco's Avatar
    Join Date
    Dec 2008
    Location
    Winnipeg , Manitoba , CANADA
    Posts
    1,445
    Post Thanks / Like
    Do yourself a favor and get a real O/P guage .
    C`mon Boy ! Prove it !
  6. #5
    Administrator Jim_Lusk's Avatar
    Join Date
    Dec 2005
    Posts
    3,533
    Post Thanks / Like
    No rallye cluster in a Dart until 1970 and then 1971 was the last year. This was also only on 340 cars.
    So, to answer your question. In 1968 there was no oil gauge in any Dart.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
