8 3/4 741 housing
+ Reply to Thread
Results 1 to 10 of 10
Thread: 8 3/4 741 housing
  1. #1
    Join Date
    Jan 2012
    Posts
    286
    Post Thanks / Like
    8 3/4 741 housing
    whats wrong with the 8 3/4 741 housing?will it handle a bigblock with close to 500hp?
  2. Remove Advertisements
    BigBlockDart.com
    Advertisements
  3. #2
    Administrator Jim_Lusk's Avatar
    Join Date
    Dec 2005
    Posts
    3,533
    Post Thanks / Like
    The 741 is the weakest of the 8-3/4 third members, but it is still strong. I've got a 489 here with 3.23 gears that could be available.
  4. #3
    Join Date
    Jan 2012
    Posts
    286
    Post Thanks / Like
    thanks but im looking for between 4.10 and 4.56.
  5. #4
    BBD LEGEND
    Join Date
    Apr 2006
    Location
    Kindersley, Saskatchewan, Canada
    Posts
    1,168
    Post Thanks / Like
    .................no problem, thats all they had when the mighty Max Wedge and Hemi 1st ruled the dragstrip.........my 11.001 440 duster pulls a 1.34 60 ft on a 4.10 factory set of gears for at least 20 years.....kim.........
    MR. Mechanic...........Panther Pink Duster* * The Beast has been Unleashed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  6. #5
    Senior Member d55dave's Avatar
    Join Date
    Aug 2006
    Location
    British Columbia Canada
    Posts
    696
    Post Thanks / Like
    There is nothing wrong with the 741. I personally have 2 buddies with them in 500plus hp race cars with no issues. As you may know, the difference in the housings is the pinion gear stem diameter. It isn't the pinion stem that fails in an 8 3/4, I have never heard of a pinion stem breaking.....
    My 2 cents
    I'd rather die while I'm living than live while I'm dead
  7. #6
    Join Date
    Jan 2012
    Posts
    286
    Post Thanks / Like
    is there a quick way to tell what gears are in there? im gonna go to the junk yard and pull a few out im looking for some 4 .10 gears,there is a big new yorker out there hopfully it has what i need,vans might have 4.10 gears?
  8. #7
    BBD LEGEND
    Join Date
    Apr 2006
    Location
    Posts
    1,168
    Post Thanks / Like
    .................Trucks and vans from 57-71 usually have 3.55 or 3.91 gears, a few had 4.10s.....big chryslers has 2.76 and 3.23s....good luck searching..........kim......
  9. #8
    BBD LEGEND Capt_Jack's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    1,101
    Post Thanks / Like
    Quote Originally Posted by mopar44075 View Post
    kinda. you can at least ballpark it. raise the car, turn the wheel one full rotation and count how many rotations the drive shaft makes. you can usually guess the actual ratio based on close observation.
    just over 3, prob 3.23's
    just over 4, prob 4.10's
    etc etc
    if its an open (non limited slip) carrier, you will either want to hold the opposite tire still or leave it on the ground to keep it from rotating. LS rear, you'll want both off the ground and just watch the driveshaft.
    I usually make chalk marks on the wheel and shaft to make things easier to guesstimate.
    its how I roll
  10. #9
    Join Date
    Dec 2005
    Posts
    241
    Post Thanks / Like
    The highest I've ever seen has been 3.91. Not saying 4.10 dont exist somewhere for the 741, but the chances of finding them seem slim.
  11. #10
    Join Date
    Jan 2012
    Posts
    286
    Post Thanks / Like
    i found a mid 60's /6 4 speed dodge truck with an 8 3/4 3.9 gears,how much differant are the drum brakes on back compared to a reg set u would put on a large bolt pattern swap?im thinking about taking it all and having it shortened to a body length if the price is right.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
