How to tell forged (steel) crank from cast crank...Please HELP! New pictures...
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 31
Thread: How to tell forged (steel) crank from cast crank...Please HELP! New pictures...
  1. #1
    Full Member daniel_depetro's Avatar
    Join Date
    Apr 2007
    Location
    Marquette, MI 49855 (The Upper Peninsula)
    Posts
    157
    Post Thanks / Like
    I bought a remanufactured 400 engine (long block) that is suppose to have a forged steel crank in it. How can I tell if the crank in my engine is forged or if it is just the standard cast crank?
    I didn't notice any numbers/markings on the ends of the crank but being installed the rest is hard to see.
    1969-1/2 A12 Super Bee, 1974 Duster 360, 1974 Duster, 1968 Coronet, 1971 Barracuda, 1970 Challenger R/T-SE, ...
  2. Remove Advertisements
    BigBlockDart.com
    Advertisements
  3. #2
    Join Date
    Dec 2005
    Location
    Ontario
    Posts
    144
    Post Thanks / Like
    Re: How to tell forged (steel) crank from cast crank
    The harmonic balancer will have a weight on it on the front if it's a cast crank. A steel crank does not. I didn't think 400's came with steel cranks from the factory, not sure though.
  4. #3
    Join Date
    Apr 2007
    Location
    Posts
    157
    Post Thanks / Like
    400s all came with cast cranks from everything I have read, however this one is suppose to have a steel crank in it. I just wanted to make sure. It is a long block thus there is no balancer on it.
  5. #4
    BBD LEGEND
    Join Date
    Aug 2006
    Location
    Long Island
    Posts
    1,941
    Post Thanks / Like
    A 400 could have a 383 crank in it, then it could have a forged crank.
  6. #5
    Junior Member Dcuda69's Avatar
    Join Date
    Dec 2005
    Posts
    83
    Post Thanks / Like
    AFAIK all 400's were cast cranks(ext. balance) I beleive 383 forged cranks(internal balance) are a bolt-in. A cast crank will have single "parting line"(from the casting process) and a forged crank will have a wide(looks like 2)parting line. I think you need to find out one way or the other so can purchase the correct balancer! good luck with your project!! 0/
  7. #6
    Full Member sr71mopar's Avatar
    Join Date
    Dec 2005
    Location
    Santa Rosa,CA 95407
    Posts
    447
    Post Thanks / Like
    According to Ma, 400's from 72-3 with 4 speeds should have steel cranks.
    Forged and cast are easy to tell apart by looking at them.
  8. #7
    Senior Member
    Join Date
    Dec 2005
    Location
    Posts
    719
    Post Thanks / Like
    Here's a pic I just took and another I found in my picture folder when I was resizing it. The crank on the right in the first pic is a cast 318. The one on the left is a forged 383. The second pic explains it nicely and is a file photo that someone else took.
  9. #8
    BBD LEGEND
    Join Date
    Apr 2006
    Location
    Kindersley, Saskatchewan, Canada
    Posts
    1,150
    Post Thanks / Like
    If it is indeed forged it will have a pilot hole for a manual trans, cast will just have a divet ..............kim............
    MR. Mechanic...........Panther Pink Duster* * The Beast has been Unleashed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  10. #9
    Newb
    Join Date
    Dec 2005
    Posts
    6
    Post Thanks / Like
    Ya'll need to remember the forged cranks on the six pack engines used external balancing.
    Bob
    70 Duster 440 eddy heads TTi's Dana60
  11. #10
    Senior Member
    Join Date
    Jan 2006
    Location
    Visalia Ca
    Posts
    749
    Post Thanks / Like
    Explain this one to me please!
    Rick
    68 Pro Street Dart
    Its not what you buy...Its what you build!
  12. #11
    Newb
    Join Date
    Dec 2005
    Posts
    6
    Post Thanks / Like
    because of the heavy rods used on the 440 sixpack engines they were the only forged cranks to use extenal balancing.
    Bob
  13. #12
    Join Date
    Dec 2005
    Location
    Ontario
    Posts
    144
    Post Thanks / Like
    Quote Originally Posted by rharveysr
    * Explain this one to me please!
    Rick
    Here's a link that shows the difference between the balancers.* Down the page shows forged, six pack and cast crank (6pk and cast have the extra weights on the front). hope this helps:
    http://www.440source.com/dampers.htm
  14. #13
    Junior Member
    Join Date
    Jan 2006
    Posts
    68
    Post Thanks / Like
    Sounds like your gonna need to pull the pan to check it against the pictures here to figure out what balancer to keep it from coming apart.
  15. #14
    Join Date
    Apr 2007
    Location
    Posts
    157
    Post Thanks / Like
    OK, there are drilled weight indentations on it and it appears it is a true drilled for a stick crankshaft. I did not see any 'parting lines' on my crank as I rolled the engine upsiode down on the stand (I did not actually spin the rotating assembly). It also has a circled '13' or something stamped on the end like a forged unit should. The cylinders on the right of the picture look like they have the rounded edges on the counter weights like a forged crank should have. Although the cylinders on the left of the picture look like they have sharp edges...
    You experts tell me, is this a forged or cast crankshaft?
    This is suppose to be a stock 400, how did it end up with a forged crankshaft?
  16. #15
    Full Member 68S's Avatar
    Join Date
    Dec 2005
    Posts
    167
    Post Thanks / Like
    Re: How to tell forged (steel) crank from cast crank...Please HELP! New pictures...
    That looks like a forged crank. Check out the pics Ski posted they should help you make the cast/forged determination.
    As far as why the engine might have originally received a steel crank, sr71mopar already posted that for you too
    Quote Originally Posted by sr71mopar
    Good luck with the project,
    Pat
  17. #16
    Join Date
    Apr 2007
    Location
    Posts
    157
    Post Thanks / Like
    Quote Originally Posted by 68S
    True, but this 400 has a casting date of 7-26-77.
    I just wanted to be sure and have a second, third, fourth,... 50th opinion...
  18. #17
    Join Date
    Dec 2005
    Posts
    194
    Post Thanks / Like
    Did it come out of a motorhome?
  19. #18
    Join Date
    Apr 2007
    Location
    Posts
    157
    Post Thanks / Like
    I have no idea where it is from. It was a 'new' remanufactured long block engine from Fliteline Engine Supply that I paid $325.00 for off of eBay about a month ago. They said it was .030 over and it came with a new Melling M63HP high pressure oil pump. I asked what it was out of and they did not know. They said Challenger/Charger VIN: LP23, N or M so that wasn't much help. It is all fresh so I figured I couldn't get a good junkyard engine for that price, especially with a fresh forged crank that was drilled for a stick (manual tranmission) like they advertised. Heck it is hard to get just the heads redone for what I paid for this engine. Too bad the compression is a sad 8.0:1. It should still make for a fun driver with all of my parts I bought for it.
  20. #19
    Join Date
    Dec 2005
    Posts
    167
    Post Thanks / Like
    To me 77 does seem a bit late to still have the forged crank but I am no expert either.
    Seeing as how these cars and their related parts have been around for so long now, you never really know what you might run into. Since your shortblock is a reman piece that crankshaft could very well have come out of a 383 or an original 400 four-speed application but it should not matter to you either way. All that really counts is that you have the good stuff and it looks like for $325 you scored a winner with that motor. The 8:1 compression part needs some help though. You will be seriously limited in cam selection with a low compression ratio like that.
    Pat
  21. #20
    Senior Member
    Join Date
    Oct 2006
    Posts
    994
    Post Thanks / Like
    it's a forged crank...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
