440 engine rough idle cam
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
Thread: 440 engine rough idle cam
  1. #1
    Join Date
    Oct 2007
    Posts
    109
    Post Thanks / Like
    hey,
    i am getting ready to assemble my 440 engine to put in my valiant i was just wondering what you guys thought would be the best cam?? i am looking for a cam that will give me a descent rough idle, but would also do good on the street.
    would probably be 50/50 street strip
    looking for a rough idle without major engine mods
    Mopar!!!!!!!!
  2. Remove Advertisements
    BigBlockDart.com
    Advertisements
  3. #2
    Senior Member
    Join Date
    Sep 2006
    Location
    92705
    Posts
    862
    Post Thanks / Like
    Re: 440 engine rough idle cam
    MP 509
    Crane 467/494
    70 Duster - Keith Black 526, 2 x 830 annulars/tunnel ram, big solid roller, 727 ProTrans, Strange 4.30s<br /><br />77 440 Dodge van 12.96 @ 108 - 4800 lbs of love with a 2.72 peg leg and 1800 stall* <br /><br />74 cheyenne 452 stroker, 2x450's on a tunnel ram, 21 foot, Berkeley jet, place diverter
  4. #3
    Join Date
    Dec 2005
    Posts
    243
    Post Thanks / Like
    Quote Originally Posted by 440valiant
    hey,
    509s idle pretty rough, but i hear they can be a turkey without decent compression, gearing etc. but that holds for any big lumpy cam. the .484 mopar cam has a nice sounding idle too and should be better on the street on a lower compresision engine with fewer mods.
    I went with an isky 292 megacam, .505 lift, 244 duration @.050, 108 lobe center. Should be better on the street than a 509 but be lumpier and stronger than the 484.
  5. #4
    Senior Member
    Join Date
    Sep 2006
    Location
    92705
    Posts
    862
    Post Thanks / Like
    Quote Originally Posted by ucdcrush
    hey,
    I've directly compared the Crane .467/.494 cam against the MP484 - the crane is quicker.
  6. #5
    Senior Member PureGTS's Avatar
    Join Date
    Dec 2005
    Location
    Los(t) Angeles, Ca.
    Posts
    971
    Post Thanks / Like
    Speedy strikes again: I agree with Sir Speedy; 509
    I ran a .509 with a low comp 383 without any difficulties. Consistant 13.3's in a B body w/4 spd. Same engine now sports a .525 solid Isky running 12.6's... on regular unleaded. Yes, compression helps, but it isn't eveything. De-tune your 10:1CR to run garbage gas or build it to run on garbage gas and full tune it. Simple choice.
    Knowledge is power, power is speed, speed is good, low E.T. is better
  7. #6
    BBD LEGEND
    Join Date
    Aug 2006
    Location
    Long Island
    Posts
    1,941
    Post Thanks / Like
    I ran the 509 cam in a daily driven 440. It was fine.
  8. #7
    Senior Member
    Join Date
    Sep 2006
    Location
    92705
    Posts
    862
    Post Thanks / Like
    Same here. Except it was a 383...
    I've run the Isky 660 solid roller on a daily driver, a .509 is no big deal...
  9. #8
    BBD LEGEND qkcuda's Avatar
    Join Date
    Dec 2005
    Location
    Caledonia, Ontario, Canada
    Posts
    1,734
    Post Thanks / Like
    Quote Originally Posted by speedymopars
    hey,
    Speedy, I'm interested in your direct comparison of the crane and the MP 484. I am running the crane in my 400 right now. By the way, it has a little lope to the idle, but has great vacuum, and nice street manners. I was considering removing the crane and sticking in the 484, but wasn't sure how much I would gain. What combo were you running it in?
  10. #9
    Senior Member
    Join Date
    Sep 2006
    Location
    92705
    Posts
    862
    Post Thanks / Like
    The crane I had only pulled 10 inches at idle, so maybe not the same cam?
    I had it in my Van's 440, and after many miles, it broke right behind the #4 cam journal. No damage other than the cam broke and stopped the 2 rear cylinders from running. Very strange.
    Anyway, I upgraded to the 484, and noticed I was a little down on power everywhere.
  11. #10
    BBD LEGEND
    Join Date
    Jan 2007
    Location
    DFW TX
    Posts
    2,148
    Post Thanks / Like
    MP 509
    Crane 467/494
    MP509 sounds real choppy.
    Hidden Content <br /> <br /><br />Hidden Content
  12. #11
    Senior Member
    Join Date
    Aug 2007
    Posts
    616
    Post Thanks / Like
    I'm running a Lunati solid lifter .577/.585 with lots of duration... it's lumpier than my wife's turkey gravy!! 10 inches of vacuum at idle in neutral. I consider it streetable (with a 3800 converter).
    1975 Dodge Dart Sport - 440
    1973 Barracuda 340
    2000 Dodge Ram 1500 QC 4x4
  13. #12
    Join Date
    Dec 2005
    Location
    Posts
    1,734
    Post Thanks / Like
    The Crane pulled 15 inches of vacuum in gear with the dual plane intake, and 13 inches with a single plane intake. I have decided to go with the new 509 cam with 114 lobe separation, since I want more power without too much lumpiness at idle.
  14. #13
    Senior Member
    Join Date
    Sep 2006
    Location
    92705
    Posts
    862
    Post Thanks / Like
    I just went onto the Mopar website to see what cams they have nowadays - what a POS website!
    2005 catalog is the "new" item there (it even says so!) and the camshaft listings are, well, a bunch of part numbers with a price. No lift, no duration, it does tell me they are purple shafts though! Thanks Mopar!
  15. #14
    BBD LEGEND
    Join Date
    Jan 2007
    Location
    DFW TX
    Posts
    2,148
    Post Thanks / Like
    The 2007 paper catalog has all that info. I have 4 of them, everytime I go to a show around here, the Dallas Dodge guys force them on you! Last show I went to I told them that I already have 2, so they gave me two more!
  16. #15
    BBD LEGEND
    Join Date
    Jul 2006
    Location
    Woodburn,or
    Posts
    1,340
    Post Thanks / Like
    I think the Mopar .528 solid works well on the street have one in my 74 duster,run the lash a couple times a summer and all's good.Car runs 12.30's off the sauce.
  17. #16
    Senior Member cu440da's Avatar
    Join Date
    Dec 2005
    Location
    Cottage Grove, MN
    Posts
    792
    Post Thanks / Like
    I have the .509 in my low comp 440. I like it, has a nice sound to it. I even bought some new pistons to get the comp into the 10's, but I'm not sure if I really want to go to the trouble since it runs so nice. Instant throttle response, and there is plenty of power at low rpm's. I'm sure decent compression would really wake it up, but I don't think it's the pig it's been made out to be.
    I used to use the .484 cam, there wasn't much of lope to it.
    '78 Warlock- 5.7 Hemi/Viper T56
    '05 Magnum RT 5.7
    '96 F150 Supercab 4x4
    '03 Kawasaki Z1000
  18. #17
    Join Date
    Mar 2006
    Posts
    343
    Post Thanks / Like
    MP .509 cam here
  19. #18
    Join Date
    Feb 2006
    Posts
    288
    Post Thanks / Like
    We are running the mopar .590 solid cam with 1.6 ratio rockers with compression in the 11.1 to 1 range, we are also running 4.30 gears, so it pulls real good once it gets pass 2900 rpm.
    This cam has gotten us in to the deep 12.02 @ 112 on street tires.
    Check out my videos, we ran a 12.06 and a 12.08 back to back. Both at 112mph
    67 Dart 383 MP590, Crane 1.6 R/R, headers, 906, 850 MIghty Demon, Performer RPM, 3inch exhausts, 727 R/M, 9.5 PTC 4500 flash stall w/ 2800 brake stall, 8 3/4 rear with P/T 4.30, on MT ET St Rad 11.71@114mph / Zex nos 11.17Hidden Content
  20. #19
    Join Date
    Jan 2006
    Posts
    364
    Post Thanks / Like
    OK,i'm old and maybe im missing the point here. What excatly are we looking for? A well build easy to drive street engine that sees a few trips down the strip each year? Or do you want a loud rough running engine that shakes the car and sounds half dead?
    I certainly do not mean to be picking on anyone, but i would much perfer the easy running street engine. Unfortunley it appears as if your building the car around the camshaft.
    Maynard
    1967 Dart GTS(orginial owner)* First "A" body orginal 2005 Mopar Nats / 2nd "A" body orginal 2009 Mopar Nats.*
    "No Fate But What We Make" (Sara Conner--Terminator)*
    WebMaster Hidden Content http://pic50.picturetrail.com/VOL433/1040825/1983287/36407184.jpg"
  21. #20
    Senior Member
    Join Date
    Sep 2006
    Location
    92705
    Posts
    862
    Post Thanks / Like
    I pulled my last cam, a .670 solid roller with 280 degrees of duration @ .050, out of my 528 becuase it idled too smooth. Had insane power, but sounded as powerful as a UPS truck. If someone is asking for a lope I can completely understand....
Posting Permissions
  • You may not post replies
  • You may not edit your posts
