Which Cam....MP .528 or SSH-44 ?
Results 1 to 4 of 4
Thread: Which Cam....MP .528 or SSH-44 ?
  1. #1
    Full Member 1968rt's Avatar
    Join Date
    Jul 2007
    Posts
    124
    Post Thanks / Like
    I think Im going to run stock HP exhaust manifolds (b-body) and was curious on which cam would be better? Motor is 440=.030, ported and polished 915s, true 10.1 comp, 4 speed with multiple gear choices. I read an article that said the 528 works well with stock exhaust....but the Racer Brown SSH-44 sounds so sweet! I also have1.5 and 1.6 rockers. Any input would help* * ***(*)
  2. Remove Advertisements
    BigBlockDart.com
    Advertisements
  3. #2
    Newb
    Join Date
    Jul 2006
    Posts
    20
    Post Thanks / Like
    Re: Which Cam....MP .528 or SSH-44 ?
    Use the 528, it's got a ton of bottom end torque. The '44 would be a dog with the exhaust manifolds and it likes lots of compression, gear, and stall. Dave
  4. #3
    BBD LEGEND qkcuda's Avatar
    Join Date
    Dec 2005
    Location
    Caledonia, Ontario, Canada
    Posts
    1,727
    Post Thanks / Like
    Would you be better off with something with more exhaust duration than intake to make up for the manifolds?
  5. #4
    Newb
    Join Date
    Jul 2006
    Posts
    20
    Post Thanks / Like
    Andy Finkenbinder did a series of articles using his street car as a test mule. His motor used the stock cast iron manifolds. One of the best cams he tested was the MP 528 solid. He tryed some custom cams and some 'modern' grind cams and the 528 was usually better with his combination. He goes by Andy F. on Moparts, drop him a PM. Dave
Posting Permissions
  • You may not post replies
  • You may not edit your posts
