August 21, 2008, 10:16:20 PM
| | |-+  Welding Sheetmetal?
Author Topic: Welding Sheetmetal?  (Read 1995 times)
Welding Sheetmetal?
« on: September 15, 2006, 08:14:48 AM »
Can anybody help me out I'm considering tackling this myself and it seems like a big job so I wanna get all the help I can get. So any input like welders, techniques, etc. I have an idea on how and I am supposed to do it because of those tech slots on tv like trucks. Like spot welding every inch and slowly closing the gap keeping the metal cool or it'll warp.
I don't suffer from road rage, I enjoy every minute of it.
My vehicles:
-1984 Dodge Ramcharger 318 auto 4x4 atc stock beast
-1968 Dodge Dart GT 6cyl auto buckets console work in progress
-1966 Bridgestone 90 Deluxe
-1946 Fargo 3/4 ton
dangerdawg
Re: Welding Sheetmetal?
« Reply #1 on: September 15, 2006, 08:55:06 AM »
tom, is the man to talk to.
dangerdawg
« Reply #2 on: September 15, 2006, 09:13:45 AM »
don't take this wrong, there are others here that can help you, so listen to them, we are all here to help that's why this is a great site.
« Reply #3 on: September 15, 2006, 02:15:40 PM »
What are you welding? Do you have a machine yet. Like Azz said, if you are using mig, .023 wire with gas; no flux core! Stitch and move around allowing the metal to cool or it will warp. It doesn't take much. Turn the heat down as low as practical with relative wire speed and move quickly. Too slow of a puddle speed will blow through so you want to move fairly quickly. A very small wiggle from side to side helps tie in the two peices together. The wiggle also helps spread the heat from the puddle around helping eliminate blow through.
The steel must be clean or the filler will not puddle. I use a wire wheel on a grinder for structural and  abrasive pads on an air tool for finish work.
Thanks for the compliments dangerdog. There are alot of capable welders on this site. jamesdart can weld anything together as well as...
Will the real eldubb440 please stand up.  duster
azz7772
« Reply #4 on: September 15, 2006, 02:17:29 PM »
i would use a small diameter wire like .023 also a mig with gas, an air nibbler is a great tool for metal fitting.
« Reply #5 on: September 15, 2006, 02:54:31 PM »
No no machine yet I was hoping the find out what i need for sheetmetal first. Like something I could use for my relocated Springs and my quarterpanels, rockers, etc.
My vehicles:
-1946 Fargo 3/4 ton
« Reply #6 on: September 15, 2006, 03:13:45 PM »
This will open up a debate like the Dana vs 8.75.
IMO, there is no comparison between a 110 and 230 vac mig machine. Get yourself a 230 vac Miller 175 mig. It will last you forever. Try www.cyberweld.com. Buy the tip cleaning tool. You don't need the cart or the little cylinder. The weld supply shops can't touch their prices. Get yourself a 140 ft3 cylinder from a weld supply shop with 75/25 gas. Get a buddy to get you contractor's price on the cylinder. Refills are about $55 but you won't runout of gas.
Hobart and Lincoln make great machines also, I am just a Miller guy. We have their spray arc, SMAW and TGAW machines at the shop including 3-8 packs that have run flawlessly for 10 years.
« Reply #7 on: September 15, 2006, 03:37:52 PM »
  never claimed to be a welding expert, but i have a lot of experience on these old rusty junkers.  experience is the best teacher, practice, practice, practice....  use plug welds where spot welds used to be... butt weld small patches..... flange and overlap long runs; dont run beads, skip around......i like working close to major body lines when hanging quarters and patch panels, the body lines help maintain ridgidity against warping.  i also prefer to prime my bare metal pieces before installation, then i clean the areas to be welded and coat with weld-thru primer. its impossible to eliminate rusting completely, but i try.  may i sit down now?  Cool
« Reply #8 on: September 15, 2006, 05:24:56 PM »
 hammer dang problem with that tom is I have no 220V plug I only have the 110V plug ins and I don't think my dad's gonna install a 220V just because. Anything similar is a 110V?
yes eldubb440 you can sit down now thanks for the comments where would I find weldable primer?
My vehicles:
-1946 Fargo 3/4 ton
« Reply #9 on: September 15, 2006, 05:28:01 PM »
automotive paint suppliers have it. i assume welding suppliers have it also. its a little pricey, dont waste it. good luck
« Reply #10 on: September 15, 2006, 05:29:36 PM »
cool thanks I'm hoping I can do it myself and save some cash damn quarterpanels are so expensive it'll take me almost one whole paycheck for one quarterpanel  lol bash
My vehicles:
-1946 Fargo 3/4 ton
azz7772
« Reply #11 on: September 15, 2006, 07:18:23 PM »
if you have room in your fuse pannel it is easy to hookup a 220 outlet just mount it close to the box it will be cheap and just get a long extention for your welder so it can reach all around your shop.
sweatybetty
« Reply #12 on: September 15, 2006, 07:36:44 PM »
i ran my LINCOLN 230v off an extension cord that i plugged into the clothes dryer socket for a while. just a thought explode
drew54
Keokuk, IA
« Reply #13 on: September 16, 2006, 12:58:56 PM »
I buy it at walmart.   Grin
« Reply #14 on: September 16, 2006, 01:02:17 PM »
didnt know they had it.......gotta love wal-mart  drinks
« Reply #15 on: September 16, 2006, 03:30:36 PM »
ifit is not practical or possible for you to run 230v for your welder, you can get away with a 135-140 amp machine. its always nice to have more though. i have one of the smaller migs, it does just about everything i need to one a car. when it comes time to do my cage, it will get tigged though.
Ed
Phoenix, Az
« Reply #16 on: September 16, 2006, 07:38:47 PM »
I with jamesdart, I have a hobart 140 120v machine and it does everything I need to do on a car.  It's on the lowest voltage setting doing thin sheet metal. If you're doing a lot of heavy stuff, you'll need a 230 welder, like building battleships.
formerly VIN_VL29U
500"Dart
More Ordered Power At Request
« Reply #17 on: September 16, 2006, 09:22:17 PM »
Hey guys...do you think there is any benefits in leaving the undercoating on the surrounding areas of a panel you are welding on, like filling the trim holes down the side on my 70 swinger.I know you have to grind the area you are welding on but I wonder if you leave the undercoat on the backside of the quarters and others panels if it would help with distortion and warping. I have alot of holes to fill, I will be striping it down to bare metal anyway but just wondering if leaving that on might help.
X
70 340 Duster
72 Roadrunner
66 Satellite
67 Coronet RT
81 Mirada
03 Bagged Quad Hemi Ram
70 318 Dart Swinger soon to be a 500" BB
65 Dart GT
« Reply #18 on: September 17, 2006, 02:26:40 PM »
X
If there is undercoating on the backside of the weld area you could start a fire as it is flammable.
You also do not want to breathe the fumes from burning undercoating.
DartAttack
dartattack68@msn.com dart_attack@yahoo.com
« Reply #19 on: September 17, 2006, 08:24:56 PM »
I sure hope your welding turns out better than my attempt hammer explode.IT aint pretty but it seems to be holding well. I am doing a lot of grinding too. Sure wish I had a gas setup to use with my mig. By the way, anybody else have problems with trunk floor extension not fitting to the quarter right?
BIG DOG
« Reply #20 on: September 18, 2006, 02:48:38 PM »
I have a Miller 135 great machine for what I want it to do.Like they have said if you are doing alot of heavy stuff get a 230 machine but if you are just working on your car a good quality machine like the miller 135 will do you just fine.I welded up all the plow gear mounts with mine 1/4 inch stuff and have used it for three years on my own driveway without anything breaking because of a bad weld.Would I have like to have had a 230 sure but for what I'm using it for mostly body or light stuff it wasn't worth the extra dollars to me .
DartAttack
« Reply #21 on: September 20, 2006, 08:25:08 PM »
Does anyone have pics of where the trunk floor extension meets the quarter panel? I want to know if the extensions were made wrong b4 I try to lengthen to to meet the bottom of the quarter.
CudaDon65
« Reply #22 on: September 27, 2006, 12:53:44 PM »
Hi , I have a hobart 140 with gas and now using 23 wire. What should the gas flow be and the wire speed be at the low amp setting ? Also, will my hobart 140(with 30 or 35 wire) be O.K.to weld the mounts for my leaf spring move ?
thank you
Duskybird
« Reply #23 on: September 27, 2006, 01:23:05 PM »
Check out millerwelds.com They have a pretty good online welding tutorial.
CudaDon65
« Reply #24 on: September 27, 2006, 02:11:34 PM »
 thank you I will take a look. Smiley
AdamR
« Reply #25 on: September 27, 2006, 08:17:43 PM »
What does every one set there regulators too ? I think Im using 75% Argon if it matters.I swapped in lighter wire today. Much better but I still need practice. Im doing way to much grinding.
www.forabodiesonly.com
Forums and classifieds
« Reply #26 on: September 27, 2006, 10:07:08 PM »
25 to 30 CFH. Watch out for wind.
« Reply #27 on: September 27, 2006, 10:31:11 PM »
i get away with  20.......Tom, does a hotter arc (thicker metal)  require more gas?   im usually welding "paper"... BTW.....i keep my machine set up with .030
AdamR
« Reply #28 on: September 27, 2006, 10:33:47 PM »
Thats my problem. I made a few patches out of nice thick stock but my big patch was thinner and I keep blowing threw it.
« Reply #29 on: September 27, 2006, 10:38:04 PM »
aaaaaah yes.......keep the arc on the thicker piece and let it kinda flow to the tinner piece, quick zaps where it starts blowin thru.
Pages: [1] 2  All Go Up Print
