October 13, 2008, 02:38:24 AM
| | |-+  Steering adapter
Author Topic: Steering adapter  (Read 844 times)
Sublime69™
Steering adapter
« on: January 15, 2006, 02:15:54 PM »
I am switching from power to manual steering. What adapter do i need to use my power column?
I know about the Mancini one, is there anything else for les that $120!
Re: Steering adapter
« Reply #1 on: January 15, 2006, 02:32:32 PM »
  i believe the flaming river one is a bit cheaper.. plus its a hell of alot nicer then that crap that mancini sells...     contact bill he sold me mine...
jet-taz
« Reply #2 on: January 15, 2006, 03:46:14 PM »
check the one from flaming river first, you might need the replacement couple too. that piece was on a lot of early b-vans, check out the bone yards .p/n 4037651 (still can be bought from chrysler for $268.00  lol
GON_RACIN
Happiness is a warm gun.
« Reply #3 on: January 15, 2006, 07:32:53 PM »
another option is to find a manual steering column and use the shaft and coupler from it.  its not as easy a swap as using an adapter, but its really not that hard to swap the shafts in the column and you might could save a few bucks.  I have pics on the old site on a post where i showed how i did mine, dunno if they are still there.
chryco
« Reply #4 on: January 15, 2006, 09:40:28 PM »
Borgesson also has stainless steal kits .
   Chryco  Wink
Hemi Darts Rule !!!!!
DartKnight
« Reply #5 on: January 16, 2006, 04:46:31 AM »
Jason
green67cuda
« Reply #6 on: January 16, 2006, 06:09:00 AM »
I used a piece of 3/4" pipe, and a piece of 3/4" round stock.  i don't remember lengths at the moment, but you basically make it so the pipe is half on the column shaft and half on the round stock, with enough round stock to make up the length difference to the coupler.  then weld it together and drill 2 holes (for the roll pins).
kinda hard to see in this pic, but i found one.
green67cuda
« Reply #7 on: January 16, 2006, 06:12:14 AM »
ahh...found another from before the "cleanup"
if I were to tdo it again, i'd probably make my pipe not extend out past the original shaft so far.  it almost touches the seal.
Dusterx0
« Reply #8 on: January 19, 2006, 01:22:31 AM »
I milled out a chunk of metal for an adapter. Bolt in the steering whel wher you want it. YOU HAVE TO BOLT IT IN i made the mistake of not bolting it in. The second time I measured and milled a sleeve then welded it in place. it was time consuming and tedius but it worked in the end. I will try and get som pics for you.
duster
65rbdodge
jeff44044mag
« Reply #9 on: January 20, 2006, 01:23:25 AM »
look no further than bill reilly. he sells the flaming river piece. i got one off of him and it worked great!
65 coronet 440/4 speed/9.75
71 dart custom 4 door 400/727/8.75
03 dakota 239/5 speed/8.25
Dusterx0
« Reply #10 on: January 21, 2006, 12:46:05 AM »
Looking at green67cuda, mine is exactly like that. If you milled it nice jobe.
« Reply #11 on: January 21, 2006, 08:36:07 AM »
GON_RACIN
« Reply #12 on: January 21, 2006, 01:39:18 PM »
DartKnight, no thats not what i'm talking about.  You can actually take the shaft out from inside the column of a manual steering car and swap it into the column of a power steering car.  The difference between a power steering shaft and a manual steering shaft is around 6 inches or so of length.  The manual and power steering boxes also use different splined couplers aswell.  If someone had a column laying around to rob parts off of this would be a simple swap and it would save 100 or so dollars.
green67cuda
« Reply #13 on: January 21, 2006, 06:20:55 PM »
here's a drawing of mine:
(maybe Bill can put it in the tech section?)
....well....crap....it's too big.
DartKnight
« Reply #14 on: January 22, 2006, 05:41:19 AM »
I see....I'm interested because I'm about to switch to manual steering myself, and the early style (key in dash) columns are hard to find; much less ones from a manual steering and floor shift A-body.  Sad
Jason
Administrator
White Haven, PA
« Reply #15 on: January 22, 2006, 11:04:14 AM »
I'll put a little page up with that drawing this evening - I want to take a few measurements today to add to it.
GON_RACIN
« Reply #16 on: January 22, 2006, 12:28:50 PM »
dartknight,  i dunno if this will work but a later model, column shift manual steering shaft might work in your earlier style column if you were to remove the steering wheel lock piece located towards the top of the shaft.  I  havent done any measuring personally, but i'd be willing to bet that the length of the shaft is same, the only difference would be that the later model column shafts have a provision for a column lock.  It might be worth looking into.
Administrator
White Haven, PA
« Reply #17 on: January 22, 2006, 11:40:07 PM »
Ok, maybe tommorow evening Smiley I forgot one measurement, so I need to get that tommorow....
