January 08, 2009, 02:34:44 AM
| | |-+  Will not STOP
Author Topic: Will not STOP  (Read 449 times)
SMOKEY
Will not STOP
« on: September 24, 2006, 03:23:01 PM »
Can use a little help. What is the real deal on the brakes on a 65 Valiant.This little car will not stop. Thanks SMOKEY
kevin383
Re: Will not STOP
« Reply #1 on: September 24, 2006, 03:58:58 PM »
Whats the engine size in the car?
Does it have a power booster?
Have you gone through the brakes?
When was the last time you bled the brakes?
Kevin383
dartracer
Strasburg CO.
Re: Will not STOP
« Reply #2 on: September 24, 2006, 10:14:00 PM »
Are they nine inch drums? If they are that's you problem. I have a 68 Barracuda that had 9 inchers that would not stop.
  Dave
GWN
Re: Will not STOP
« Reply #3 on: September 24, 2006, 10:29:13 PM »
Its time to upgrade to a better brake system,GWN
DartKnight
Re: Will not STOP
« Reply #4 on: September 24, 2006, 10:33:09 PM »
If they are drums, just remember that self-adjusting brakes will only self-adjust when everything is working properly. That means replacing ALL of the hardware when doing a brake job; including the cables and adjusters. That stuff wears out pretty quick.
Jason
72polara
Re: Will not STOP
« Reply #5 on: September 25, 2006, 11:07:05 PM »
Did you already check things like oil on the shoes, brake fluid on the shoes, etc?  If you've got leaky wheel cylinders, that doesn't do much for stopping power.
SMOKEY
Re: Will not STOP
« Reply #6 on: October 13, 2006, 08:48:42 AM »
Well  there junk. Even when they were NEW. We went to Disc.   Thank's  SMOKEY.
