Topic: 11.75 disc setup (Read 2022 times)
jedrattle
I know there was a tech post on a mopar board somewhere but I can't seem to find it. I want to know what parts off of what car to get this setup. I have the big bolt pattern brake setup now but want a bigger set up since I need new rotors.
dartracer
I found mine on a 88 Fifth Ave. Dave
I got some off a 77 Fury.
also there is another difference
i believe that the 76-78 had the pin style where as the 79-81 had the slider style
i choose to go with the slider style because it seems simpler to me, but go with what ever you allready have
also the brackets i got are off a 79 cordoba and the guy said they were the heavy duty ones, i compaired them and they seem to be alittle thicker, but i dont think it makes a diference
Scamp
This is what I'm using on my 71 Scamp: 11-3/4 Cordoba Rotors Cordoba streering knuckle (spindle) 73 Dart upper control arm Hughes racing ball joint Porsche 4-piston Caliper Custom adapter Can't see where/how to insert pics??
jedrattle
Thanks for the responses! This is what I'm using on my 71 Scamp: 11-3/4 Cordoba Rotors Cordoba streering knuckle (spindle) 73 Dart upper control arm Hughes racing ball joint Porsche 4-piston Caliper Custom adapter Can't see where/how to insert pics??  How is this working? Porsche caliper? Who makes that bracket? With the picture you need right click on it and get the properties of the picture. Then copy and paste in to the [img] thingy.
Scamp
Thanks for the responses! This is what I'm using on my 71 Scamp: 11-3/4 Cordoba Rotors Cordoba streering knuckle (spindle) 73 Dart upper control arm Hughes racing ball joint Porsche 4-piston Caliper Custom adapter Can't see where/how to insert pics??  How is this working? Porsche caliper? Who makes that bracket? With the picture you need right click on it and get the properties of the picture. Then copy and paste in to the [img] thingy. I designed the caliper adapters and had them machined. The Calipers are 4 piston aluminum from a Boxster 'S' (Brembo). Slight correction to my configuration ==> The spindles are 73 Dart Seem to work fine but so far I haven't left the driveway, Lights this weekend! I also have 2004 Mustang Cobra 11.69" Disc on my 8-3/4 rear. Also my design.
dartracer
I would like to see some pics of the rear disc set up.
Scamp
Glad to; tell me how to post them or send me an email.
daniel_depetro
1974 Dart Sport, 1974 Duster, 1971 Barracuda, 1974 'Cuda, 1970 Challenger R/T-SE, 1970 Challenger 340, 1971 Challenger 340, 1968 Coronet, 1970 Duster 340, (x2) 1973 Duster 340, 1971 Demon, 1972 Demon, 1973 Dart Sport 340, 1973 Dart Sport, 1977 Volare, 1971 Dart, 1970 Dart
Scamp
Front & Rear pics emailed
daniel_depetro
I got your pictures later tonight I'll upload them and post them up.
This kit is far more advanced than the Mopar Action budget parts swap.
daniel_depetro
daniel_depetro
375InStroke
You need to make at least 10 posts before you can post pics. I guess it's to reduce spam. Once it's enabled, click the second button in the second row at top that looks like this:  Hover over the buttons and it gives a description of what it does.
What wheel is this? I really like it!
daniel_depetro
Looks like it has the 'Hot Wheels' logo in the center. Do a search for hot wheels 17 inch 5 spoke or hot wheels 17" 5 star and see what you find...
daniel_depetro
great setup, but those rotors are alittle rusty, you need to drive that car more
Damn, I think I just fell in love. I have to get me a set of those in black now.
Scamp
My apologies for taking so long to post your pictures. I forgot about this thread. Here are the pictures. If this picture doesn't make your mouth water than you are on the wrong forum. I was awe-struck by the hotness of this rear.  I just found this thanks to you all for the kind words about my work. Scamp
daniel_depetro
Scamp
Thanks for your attention to details and quality craftmanship! If you ever have an extra laying around that you want to send me feel free. I'll PM you my address.  I do not know why some of the pictures are not working anymore though...
Scamp
Thanks again. There seem to be a number of people who would like to see the pics and now that I have 10 posts I'm going to post some. We will see if it works!  Some of this is duplicated in other posts but without the pics. This is what I did: 71 Scamp w/73 Dart K-Frame, UCA/LCA, Spindles Schumacher mounts and a 383/727 Front = 11.75” Cordoba Rotors with Porsche Boxster 'S' 4 piston Calipers (Brembo). (CNC adapter I designed) 13+ front Rotors coming and maybe brackets for sale if there is enough interest B-Body rear narrowed w/Moser axles and MP spring relocation kit (not in Frame only .8”) Mustang Cobra 11.69” rotors and calipers on the rear. (CNC adapter/brackets I designed) E-brake cables from Cobra work but drivers side had to be shortened. Wheels & Tires: 17” x 8” x 12mm KMC Hot Wheels 68 with 255/40x17 Pirelli P Zero on the front 17” x 9” x 24mm KMC Hot Wheels 68 with 275/40x17 Pirelli P Zero on the rear There is NO room for any more tire but then that’s the idea. Isn’t it? :>) YES, I've driven it and nothiing rubs! I haven't yet tested/measured stopping distances but I expect <110' from 60. We'll see. Note: There are no spacers on either front or rear and I had custom centering rings CNC machined so that they are hub-centric. These wheels are only available at Discount Tire http://www.discounttire.com These are the same wheels Rick Ehrenberg used on the Bold Beeper. I’m think he used 0mm offset all around. Note: The 17x8x12mm offset do not show up on the website but they are available! Make the counter guys check stock. Lucky for me my son works at Discount and he searched and found them. These are great looking wheels for the price. You can see the rear above in this post: http://www.bigblockdart.com/index.php/topic,10486.0.html Here is a question for you pros (in the business). What's an 8-3/4 built like this worth?? PM me for pics if you like. Scamp
Scamp
Hey it worked!
Some more
