Topic: Sway Bar Qs... (Read 358 times)
70swingergt
I currently have the 67-72 small block k-member with the factory sway bar setup. I want to install the later 73-76 spool k-member and reuse my lower control arms/sway bar setup...will this work? I don't care about the center radiator support brace as I don't have it installed, anyway. Thanks for the help! BTW, this is in a 70 Dart with a 440. Jim DartGT1970@Yahoo.com
1970 Dart Swinger, 440/727/3.91sg
Keith Mopar
The sway bar for 73 - 76 must bo through the K member. For sure the sway bar K frame mounts won't work. If you use the LCA from the pre 72 you could have trouble bolting a sway bar up!
Keith Mopar 74 440 Duster, 65 360 Cuda, 89 super 60 Shadow, 99 Ram, 96 Avenger, 91 Daytona, 91 Lebaron Convertible
All you have to do is drill the frame mount holes on the front edge of the k-member. Some early ones had the holes there already and some had the holes in only one half. Easy swap.
70swingergt
Thanks, Jim! You ALWAYS have helped me out in a pinch. Jim
Keith Mopar
The problem is, You'll have the LCA for early car and K frame for a later sway bar. Now what sway bar will you use! If you use the one for the K frame it won't be wide enough for the mounts on the LCA. The sway bars are different widths arn't they! I tried this and ended up cutting the LCA sway bar monts off and fabbing new monts closer in. We'll mayba I'm having a  ! LIke it's never happened before!
Tacfire11
When you swapping your K? This will be next task as I drop the 440 in
Keith, he's using his current LCAs and sway bar.
But, you are correct about the differnet widths.
Keith Mopar
Yup, Jim that is exacly what I had, a 69 Dart (383) with a 76 spool mount K frame. I used the LCA'a from the 76, and when I went to put the sway bar in, the mounts wouldn't bolt up to the k frame. It had those goofy triangular mounts. I had to fabricate brakets for the k frame and then, as I said earlier change the LCA mounts to the earlier style brackets.
We'll I'm not going to say I didn't screw up, but maybe 70 swinger can let us know what happens!
268darts
I saw a pic of the old style swaybar and lower control arms with a 73 up k-member. It had the links shortened to like maybe .5 - 1" long. Shortened links = clearance for calipers. The newer control arm brackets were fliped and the bar narrowed to clear the disc brake calipers.
