Topic: 273 Commando? (Read 685 times)
3404bbl
I have a 273 out of a 67 Barracuda that's going into my 63 Dart until I get my 360 built. I was just curious about it. It has aftermarket valve covers and a Holley 4 barrell, so I'm doubting it is a high performance 273. Is there an easy way to tell?
6469mopar
I would run the # s on the block
barracudadave67
340 The #s are on the block under the drivers side head, it will have some #s then 273-4, if it is a 67 273 Commando motor.
69 B-Cuda FB340 4V 323 8 3/4 67 B-Cuda NB 2734V 323 8 3/4 66 Dart Gt 273 Project 97 Ram 4x4 99Ram 4x4 91 Ramcharger 4x4 bought new in 90- restoring
Burlington Wisconsin
65val
BC, Canada---eh?
340 The #s are on the block under the drivers side head, it will have some #s then 273-4, if it is a 67 273 Commando motor. Sorry to say,but having "-4" after the casting number does not mean its a Commando 4 barrel engine. The "-4" is the number of times that sand cast has been used to cast a block. I've personally seen a"-7" after the casting number,and I dont think they made 7 barrel engines. The only way to positively tell if its a hi-compression 273 is to look into the bores and see if the 10.5:1 pistons are in there. Anyone can swap the dual-point distributor,black-wrinkle valve covers,cast iron 4 bbl intake and AFB carb,and 4 barrel camshaft into a standard 2 barrel engine. Just FGI(for general info.), there is no such thing as a "Commando block", "Commando heads", or "Commando exhaust manifolds". These are the same as the 2 barrel versions...And ALL '64-'67 273's came with solid lifters...2 or 4 barrel. '68 and '69 273's were hydraulics. To tell what year the block is,look on the machined pad on the block front, to the right of the timing cover (driver's side)...There will be a letter and some numbers. The letters start with "A",which is '65,"B"= '66,"C" = '67,and so on. A '67 273 should say "C273". Hope this helps...
Darwin/BC /Canada
'65 Cdn. Valiant Custom 100 'vert 225/A833...eternal project
'67 Dart GT 'vert 273/904...now with "Collector" status
