November 21, 2008, 09:15:39 PM
| |-+  Early A-bodies
| | |-+  273 Commando?
Author Topic: 273 Commando?  (Read 758 times)
3404bbl
273 Commando?
« on: September 28, 2006, 11:22:54 PM »
I have a 273 out of a 67 Barracuda that's going into my 63 Dart until I get my 360 built. I was just curious about it. It has aftermarket valve covers and a Holley 4 barrell, so I'm doubting it is a high performance 273. Is there an easy way to tell?
6469mopar
JACKSON, NJ
Re: 273 Commando?
« Reply #1 on: September 28, 2006, 11:35:10 PM »
I would run the # s on the block
barracudadave67
Re: 273 Commando?
« Reply #2 on: September 29, 2006, 01:02:37 AM »
340
The #s are on the block under the drivers side head, it will have some #s then 273-4, if it is a 67 273 Commando motor.
bbd sign
69 B-Cuda FB340 4V 323 8 3/4
67 B-Cuda NB 2734V 323 8 3/4
66 Dart Gt 273  Project
97 Ram 4x4
99Ram 4x4
91 Ramcharger 4x4  bought new in 90- restoring
Burlington Wisconsin
65val
BC, Canada---eh?
Re: 273 Commando?
« Reply #3 on: September 29, 2006, 01:17:56 AM »
340
 bbd sign
Sorry to say,but having "-4" after the casting number does not mean its a Commando 4 barrel engine. The "-4" is the number of times that sand cast has been used to cast a block. I've personally seen a"-7" after the casting number,and I dont think they made 7 barrel engines.
The only way to positively tell if its a hi-compression 273 is to look into the bores and see if the 10.5:1 pistons are in there. Anyone can swap the dual-point distributor,black-wrinkle valve covers,cast iron 4 bbl intake and AFB carb,and 4 barrel camshaft into a standard 2 barrel engine.
Just FGI(for general info.), there is no such thing as a "Commando block", "Commando heads", or "Commando exhaust manifolds". These are the same as the 2 barrel versions...And ALL '64-'67 273's came with solid lifters...2 or 4 barrel. '68 and '69 273's were hydraulics.
To tell what year the block is,look on the machined pad on the block front, to the right of the timing cover (driver's side)...There will be a letter and some numbers. The letters start with "A",which is '65,"B"= '66,"C" = '67,and so on. A '67 273 should say "C273".
Hope this helps...
So, if you can't Drink'n'Drive, why do pubs have parking lots?
Darwin
'65 Cdn. Valiant Custom 100 'vert
225/A833...eternal project
'67 Dart GT 'vert
273/904...now with "Collector" status
