January 09, 2009, 09:44:04 PM
| | |-+  Toyota Alternator Conversion
Author Topic: Toyota Alternator Conversion  (Read 279 times)
moparn1
Full Monty Racing
« on: October 03, 2006, 12:46:05 AM »
is anybody running or have run a toyta alternator in they're car. i hooked one up and its only putting out 12.0 volts at the alt. and at the battery. i have the sense wire to the started relay and the charge wire to the battery. any suggestions?HuhHuhHuh hammer thank you
bow chicka bow wow
lake worth, florida
55robert@comcast.net
Re: Toyota Alternator Conversion
« Reply #1 on: October 04, 2006, 10:56:33 PM »
reckon the wire should go to a light bulb instead of a relay.
Bogie
Bogie7177@Hotmail.com Bogie7177 Bogie7177
« Reply #2 on: October 05, 2006, 04:40:49 AM »
Change the sense wire to a switched leg from the ing switch usually whichever feeds the ing system fo a internally regulated Alt. if its a ext regulator the stock mopar one can control it just hook up the field wires & the charge feed.
66 Dart 170 2 door Sedan 273 HP,A833,8 3/4 W/3.90's, Front Disc,Radio Delete
84 W350 1 Ton Crew Cab 360.NP435,D60's W/4.10's,9" Lift,37" SSR's
moparn1
Full Monty Racing
« Reply #3 on: October 05, 2006, 04:47:17 PM »
ok so there is a three wire plug on the alt. 1-for ign lead, 1-for the sense, 1-for a light the ign is hooked to the wire that used to run to the external regulator and the sense is to starter relay and the light is not used. should i hook the sense and ign wires at the same place?Huh?
bow chicka bow wow
