May 17, 2008, 06:50:52 AM
| |-+  Early A-bodies
| | |-+  Hydraulic clutch to early A-body
Author Topic: Hydraulic clutch to early A-body  (Read 1502 times)
maxvo2
« on: October 04, 2006, 06:44:50 AM »
Has somebody in his A-body hydraulic clutch (cylinder to pedal and between clutc fork)? Can you send a pictures / links. I'm planning to install to my 65 Valiant that kind of system. Car is equipped 318+A-833 4-speed. thank you
sweatybetty
Re: Hydraulic clutch to early A-body
« Reply #1 on: October 04, 2006, 11:41:25 PM »
here you go
« Reply #2 on: October 05, 2006, 12:12:38 AM »
Hey sweaty is that your red car before you painted it?
maxvo2
« Reply #3 on: October 05, 2006, 12:46:17 AM »
Exelent work!! Can You send parts numbers and manufacturer of those parts, the master / slave cylinder? It would be easyer to get parts...  Living little bit far away US, in Northern Europe Finland! In which car you have done that swap? Cheesy
sweatybetty
« Reply #4 on: October 08, 2006, 02:32:12 AM »
Grin yep
dart44072
« Reply #5 on: October 09, 2006, 02:43:22 PM »
Nice stuff Sweatybetty! Can you send me that list also? So all I need from the original set-up is the pedals,  bellhousing and internals?  4 speed 4 speed 4 speed 4 speed 4 speed 4 speed 4 speed
dartcharger_270
« Reply #6 on: October 11, 2006, 07:03:18 PM »
I would like that info too!  Grin
1965 Dodge Dart 270 HT
1965 Dodge Dart 270 Wagon
sweatybetty
« Reply #7 on: October 11, 2006, 11:46:09 PM »
heres the links
http://store.summitracing.com/partdetail.asp?autofilter=1&part=WIL%2D260%2D1333&N=700+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=WIL%2D260%2D3376&N=700+4294922533+4294839072+400196+4294852250+115&autoview=sku
this was pretty simple to do. i did have to fab the linkage from the pedal to the m.c. and a bracket for the rubber line and the bracket for the slave cylinder. i havent tried it out yet but theoretically it should work. also had to make a 1/8" plate to back up the firewall. thanks for all the comps  thank you
dart44072
« Reply #8 on: October 12, 2006, 03:49:52 PM »
 thank you Sweatybetty! The threaded rod from the slave cyl to the clutch arm, Was that a mod also? Looks real good drinks
maxvo2
« Reply #9 on: October 31, 2006, 07:26:46 AM »
Hello sweatybetty!
have You allready got that hydraulic clutch in use? Does it work ok? Is there any problems? Smiley
rharveysr
« Reply #10 on: March 24, 2008, 03:51:13 PM »
Any results on this yet?   We are needing to make a choice on one or the other. The hydraulic would make more room that doing the Z bar when it comes time to run the headers..
Pictures of how you did the brackets would be great...
