September 07, 2008, 07:32:35 AM
| | |-+  Quarter Panel Advice
Author Topic: Quarter Panel Advice  (Read 670 times)
xssive
« on: October 10, 2006, 11:12:08 PM »
I am looking for advice/recommendations regarding quarter panels for 69 Dart GTS.   I've read threads here stating that much of what is available is junk.  I'd be interested in hearing feedback on quality panels.  I'm expecting that I'll have to go with a repro reseller and that I'll likely keep most of my original quarters and just use the lower half to replace the rusted areas.  If anyone has information or helpful advice, it will be much appreciated.  Thank you in advance!
Vince
Ed
Phoenix, Az
Re: Quarter Panel Advice
« Reply #1 on: October 11, 2006, 04:33:31 PM »
Welcome.   Patches are easier to do then a whole quarter, at least for me.  Do you have them all cleaned up and can you post some pics?
formerly VIN_VL29U
« Reply #2 on: October 11, 2006, 06:27:52 PM »
Replacement quarters are not full quarters and are thinner than the original metal. They fit ok. We had them installed on my son's GT convertible. Fortunately my GTS doesn't need that much work.
jimmyb
« Reply #3 on: October 11, 2006, 06:30:34 PM »
here are mine I bought them from year one.
Blown 572 Hemi
Work in progrees
Engine by Dram
6pkScamp
Small block Scamp Brooksville,Fla.
« Reply #4 on: October 19, 2006, 07:00:20 PM »
I also sm looking for companies that sell quarters. Just finished the mini-tub on the Scamp, now time to get rid of the cancer. I'll most likley get a whole quarter and just use what I need. The going price seems to be between $200 and $230. Already looked at Year one, Paddock, Classic one and Jims auto parts. Lets hear you guys.
onlyas
« Reply #5 on: October 19, 2006, 11:30:10 PM »
just got a pair of Goodmark quarters for a Duster from jeg's. $410.00 to my door
dustertogo
« Reply #6 on: October 20, 2006, 12:56:22 PM »
Most of them come from the same place and just get different names put on them. I got mine from year one and they look the same as the ones from Cross Canada panels. They even have the same sticker on them. But unless you find a rust free car you can cut them off(pretty hard to do in Canada) they are all you get. Just use what you need. They will take a bit of work to look nice but they will be fine.
sickt7cuda
« Reply #7 on: October 20, 2006, 04:56:08 PM »
Year One bought the molds from Ma Mopar.  Those are the ones I used.  The fit was great, although they were on the thin side.  Unless you can find OEM panels - good luck - you are going to have to work with the aftermarket stuff.  I'm a fairly talented (insert humility) body/panel guy, and they turned out perfect.  I even had to widen the wheel wells and I dare anyone to find signs of that being done....short of taking measurments.
505 - 400 block
EZ-1's, 4.56 gear, 8" PTC 4500 stall
best of 1.402 60', 10.338 @ 128.73
feff
« Reply #8 on: October 20, 2006, 05:23:21 PM »
Not to be an azz, moon  but i worked for year one for years and they don't make any of there parts Roll Eyes  they may have worked with another company to get the molds from ma-mopar but they don't make them in house.
Mopar, What else is there to drive
Evan
Fayetteville, Arkansas
bigjohncat
« Reply #9 on: October 24, 2006, 10:53:08 PM »
I dont mean to steal this thread, but do you guys like to butt weld them or flange them? thanks in advance,     -Evan
« Reply #10 on: October 24, 2006, 11:05:28 PM »
i only butt weld small patches.......overlap big stuff, flanging is nice where you can use it
Evan
bigjohncat
« Reply #11 on: October 24, 2006, 11:14:42 PM »
eldubb - for a full quarter, would you recommend flanging or overlapping, or what? if you overlap, how do you hide the seam? filler? thanks as usual!   -Evan
« Reply #12 on: October 24, 2006, 11:34:27 PM »
everyone has there own way of doing things.....that said; flanging, if we are talking bout the same thing (putting a "step" in the sheetmetal); works great on flat runs. it actually gives the "edge" a little rigidity and allows for a nice level overlap..... some cars; my gtx for example; i overlaped the top bodyline. leaving it on both pieces giving both of them rigidity.  i did the same on my coronet lower panels; overlapped the bodyline. i butt welded the front near the wheel opening, and the back near the bumper..........after welding, i grind it and put a layer of marine-tex (a nasty epoxy) over the area. then i grind that flat, and proceed to bodyfill.... heres a pic of the coronet patch.  i only tacked it on the inside. ill epoxy the inside too.
Evan
bigjohncat
« Reply #13 on: October 25, 2006, 11:13:41 AM »
do you overlap on a bodyline, or on a flat spot?   thanks for the info,     -Evan
« Reply #14 on: October 25, 2006, 11:34:35 AM »
flange the flat spot if thats where your gonna work. (it can be done without flanging, but flanging adds strenth) its hard to see in my pic, but the bodyline is above the welded seam and below the marks left from tacking on the inside..........  working near a strong area, such as a body line will help prevent warping. IMO.... heres a pic after its been grinded(ground?) maybe ill remove the sticker one day hammer
Evan
bigjohncat
« Reply #15 on: October 25, 2006, 02:51:33 PM »
ok, thanks a bunch,         -Evan
