October 16, 2008, 12:57:31 AM
| | |-+  drip rails
Author Topic: drip rails  (Read 1082 times)
nu-skool-dart
drip rails
« on: January 17, 2006, 10:20:52 PM »
i was wondering if anybody has done this or has pics of an a-body with out the drip rails. i know that the drip rail is where the roof skin is welded on. the part that i think there is going to be a sight issue is in the door jam because of the stainless steel trim that holds the door gasket on. i don't do many posts but i enjoy what all you guys have to say. any suggestions would be great. thanks joe
rjsjea
ProTouring Demon
Re: drip rails
« Reply #1 on: January 18, 2006, 01:23:20 AM »
I dont have pics (yet) but I shaved them off my Demon couple months ago....it was sort of a pain. I cut 3 inch sections then welded, cut-weld,cut-weld,cut-weld and so on....The stainless roof rail trim will be an issue, my builder (Schroeder speed and custom) wants to cut it in half lengthwise so it will not be seen but I havent decided.
ski
Re: drip rails
« Reply #2 on: January 18, 2006, 01:34:40 AM »
I seem to recall that Mike R shaved the rails on his dart.
ski
Re: drip rails
« Reply #3 on: January 18, 2006, 01:37:18 AM »
Yup, go to the gallery and look under his photos.  There's a nice rear/side shot of it.
nu-skool-dart
Re: drip rails
« Reply #4 on: January 18, 2006, 09:09:45 PM »
thanks for the help. i think mike r's car looks really good with out the drip rail.
rjsjea, let me know how spliting the trim piece works out sounds like that is a good idea.
vancamp
VanCamps Paintless Dent Repair
Re: drip rails
« Reply #5 on: January 19, 2006, 08:43:54 AM »
Havent done drip rails but it is the same concept as the top lip on the quarters on a 66 charger I done for a friend, just cut and weld small sections at a time to keep from warping the metal then take a small grinder or DA and finish the metal
drjay0
Re: drip rails
« Reply #6 on: January 19, 2006, 02:28:11 PM »
Go find a pic of Butch Leals Pro Stock car. That car also had Ebody door handles. That car was bad ass.
263 Posts on old board. Member since March 2003.
"Where the hell do i go to tell the world my dog died or my gf is in jail or my penguin ran away!" -njsuperbees
nu-skool-dart
Re: drip rails
« Reply #7 on: January 20, 2006, 10:51:16 PM »
where can i find this pic
drjay0
Re: drip rails
« Reply #8 on: February 06, 2006, 03:33:32 PM »
Here is what you need to see. BAD ASS!!!!
photos from http://www.prostockhemi.com
Thanks Fred !!
Jason
MikeR
Re: drip rails
« Reply #9 on: February 15, 2006, 02:40:54 PM »
One of the cool things about this modification is that most people don't even notice, it's something that just looks right when it's finished.  For the weather stripping I used an adhesive tape (used for trim on newer cars) purchased from a paint supply shop, it holds really well but I have had a problem with the top forward corner, the rubber doesn't want to stay tucked into the corner.  I'm planning to go to a local street rod shop to find out what they do in this situation, maybe there is a different type of weather stripping.  I don't know that it's a big deal but it doesn't look "perfect" in that 1" x 1" area.
StripeHOG
Greentown, IN
Re: drip rails
« Reply #10 on: February 15, 2006, 03:18:57 PM »
gotta love those old pro stockers
Andrew Brough
372Z 69 Dart GTS bbd sign
1.46 60' 7.06 95mph so far
Darren
Re: drip rails
« Reply #11 on: February 23, 2006, 07:07:48 PM »
Hey guys I am thinking of shaving my drip rails on My car (68 dart).  It already has shaved door handles. And in the process of shaving the gas cap. Any way what I want to know is, what size of gap are you left with, that has to be welded when the rail is cut off.  Thanks   Darren
MikeR
Re: drip rails
« Reply #12 on: February 23, 2006, 07:22:37 PM »
I had almost no gap, this is where the body panels are pinched together.
Darren
Re: drip rails
« Reply #13 on: February 23, 2006, 10:23:45 PM »
Mike what did you use to cut the rail with? If you used a sawsall did you cut from the top or bottom of rail. I also have a plazma cutter but I think it will produce to much heat. And one more thing you cut flush with the roof line leaving no lip correct? Thanks   Darren
MikeR
Re: drip rails
« Reply #14 on: February 24, 2006, 12:08:26 AM »
I used a grinder to cut the drip rail off, and left no lip.  I just took it slow.
Don't forget about the weatherstripping issues.
rjsjea
ProTouring Demon
Re: drip rails
« Reply #15 on: February 24, 2006, 04:38:39 AM »
I used a cut off wheel.....almost no gap after I took off each section
Darren
Re: drip rails
« Reply #16 on: February 24, 2006, 07:21:59 PM »
I will be starting on the rail removal tommorow.  I will try to get some pics tommrow nigt.  Thanks for the help. Darren
nu-skool-dart
Re: drip rails
« Reply #17 on: February 26, 2006, 10:50:20 PM »
Darren, not sure if you got my message.  No i haven't shaved the rails yet.  I'm still trying to figure out the weatherstrip issues.  I think I might slit the original stainless weatherstrip retainer slide it back and use a body weatherstrip from a newer car.  Basically using the stainless as pinchweld.  i will try to post pics when i start this project.
Darren
Re: drip rails
« Reply #18 on: February 26, 2006, 11:08:11 PM »
nu skool dart I did mine this weekend looks pretty good, lots of work spent 4,5 hours each side. what year is car.  Darren
nu-skool-dart
Re: drip rails
« Reply #19 on: February 26, 2006, 11:24:18 PM »
my car is a 67 dart.  what did you do for the weatherstrip.
Darren
Re: drip rails
« Reply #20 on: February 27, 2006, 08:25:33 AM »
nothing yet, I will try and modify the steel trim.  Darren
Daniel
Re: drip rails
« Reply #21 on: March 05, 2006, 11:27:18 PM »
I used a sawzall to cot mine off.
