November 20, 2008, 04:33:42 AM
| | |-+  17" front wheel/tire info needed
Author Topic: 17" front wheel/tire info needed  (Read 705 times)
« on: October 13, 2006, 07:25:18 AM »
The current 17s on the front of the Dart are going to get replaced with something that fits better.  Currently I have an 8" wide wheel, and it is just to much as it scrapes the fender.  I was going to get another set anyway, because the backspacing is not correct (needs a little more).
I know some of you run the mustang wheel, what size are they and the tire?  Is there anyone running an 8" wide 17" wheel on a the front of a Dart?
Administrator
White Haven, PA
Re: 17" front wheel/tire info needed
« Reply #1 on: October 13, 2006, 10:53:18 AM »
17 X 8 with 5.72" backspace, with a 225/50/17 tire....on the alterk with wilwoods, which is about the widest stance - the other brakes options are narrower by a little bit.
« Reply #2 on: October 13, 2006, 08:54:59 PM »
That is more backspacing, and a smaller tire.  How close are those to the front of the fender?  I still have the "cheapo" brake setup, which should give me even more clearance to the fender, but possibly less, lock-to-lock, right?
Thanks Bill.
Administrator
White Haven, PA
« Reply #3 on: October 14, 2006, 12:02:03 AM »
To the front of the fender there's lots of room - over an inch. In fact, even with the tire partially up inside the well, I still have full turning radius without hitting the top of the opening. And with the iron rotors, you have 1/4" more clearance than that yet - you should be in great shape.  On the turning radius, I found these rims clear the tie rods just fine, although very close when fully compressed and tunred at the same time - an unlikely position...
« Reply #4 on: October 14, 2006, 08:08:36 AM »
Sounds great.  So no trimming on the fender anywhere, eh?  That will allow me to go to some better brakes in the future too, with no worries.
Thanks again!
« Reply #5 on: October 14, 2006, 08:43:53 AM »
Ok Bill.  One more Q. The AR THIIs are only sold with a max of 5.5 backspacing on the 8" wide wheel, unless I get a custom offset (ouch).  Do you think this is pushing it as far as clearance goes?  I know there are a few more guys around here running these...
Thanks.
Sacramento CA.
« Reply #6 on: October 15, 2006, 12:51:14 AM »
I have 1/2" spacers with mine that gives it 5.22" back space. That is about as far out as mine can go with the ride hieght I have.
« Reply #7 on: October 19, 2006, 05:50:43 PM »
on my 67 valiant i got 18x8.5 with 245/4018, 76 disc brakes 5.75 ofset car lowered a bunch and still have no rubbing on sides but on the top of the wheelwell it hits if i hit bumps at higher cruzing speeds.oh and inner fender slightly trimmed
