January 09, 2009, 09:46:51 PM
| | |-+  Differential Pinion Thrust Spacers Questions
Author Topic: Differential Pinion Thrust Spacers Questions  (Read 165 times)
6ix5ive
« on: October 16, 2006, 12:49:25 PM »
Hello
These maybe  dumb questions.
What is the purpose of the Differential Pinion Thrust Spacers used in a 8-3/4" rearend?
Where do they go and what is the best way to install them?
Thanks for any responses
AAOUTLAW
Otis Rules !
Re: Differential Pinion Thrust Spacers Questions
« Reply #1 on: October 17, 2006, 05:24:48 PM »
They set pinion preload and go between the pinion stem and the bearing
6ix5ive
« Reply #2 on: October 20, 2006, 11:41:49 AM »
If I have non adjustable bearings on my axles do I need the spacers?
1DART440
« Reply #3 on: October 20, 2006, 03:37:36 PM »
The trust spacer is used for tappered axle bearings (factory). There is an adjuster on one axle only and the trust spacer transfers the preload to the other bearing. When you use non-adjustable green bearings on your axle you can leave the spacer out.
