July 09, 2008, 12:08:34 PM
| | |-+  Slider width
Author Topic: Slider width  (Read 523 times)
440Demon
Streetsboro Ohio
Slider width
« on: October 24, 2006, 07:46:59 PM »
Hey Bill,
Or anyone else that might know the answer.
I have a set of Caltrac Mono-leafs and I want to
use your Sliders instead of shackles.
I heard the Sliders aren't wide enough to accommodate
the Mono-leaf springs.
Is this true?
If so how do I  fix this problem?
Thanks
lake worth, florida
55robert@bellsouth.net
Re: Slider width
« Reply #1 on: October 24, 2006, 09:09:11 PM »
saw, weld
440Demon
Streetsboro Ohio
Re: Slider width
« Reply #2 on: October 25, 2006, 03:44:39 PM »
Or grind the spring down till it fit's in the slider.  cat fight demon
Birdius Rapidus
Re: Slider width
« Reply #3 on: October 25, 2006, 04:51:09 PM »
I will measure mine when I get home in a few hours.
Tom
drew54
Keokuk, IA
Re: Slider width
« Reply #4 on: October 25, 2006, 08:47:01 PM »
I have caltracs and sliders, fit fine  Huh
Drew
68 Dart Post-572 KB-Stage V Hemi
http://www.myspace.com/154215108
440Demon
Streetsboro Ohio
Re: Slider width
« Reply #5 on: October 25, 2006, 09:25:46 PM »
I will have to measure my springs and then
find out how wide the sliders are.
Someone told me they wouldn't fit.
Do you have any pics of your slider set-up?
Birdius Rapidus
Re: Slider width
« Reply #6 on: October 25, 2006, 10:05:38 PM »
2 7/8" inside dimension
440Demon
Streetsboro Ohio
Re: Slider width
« Reply #7 on: October 26, 2006, 05:43:45 AM »
Thanks Tom   thank you
Crazy68Dart
Re: Slider width
« Reply #8 on: October 26, 2006, 07:27:52 AM »
I thought the bushing size was the issue with the Calveert monos?  That is the reason I did not move forward, at least right now...
440Demon
Streetsboro Ohio
Re: Slider width
« Reply #9 on: October 26, 2006, 08:27:37 PM »
Well I measured my Mono-leaf spring.
It is 2 1/2"  or 3 1/8" if I use the washers like in my
picture.
As far as the bushing goes, I believe Bill has the right
size bushing for them.
If not I am a machinist, I will make my own.
Blue
Re: Slider width
« Reply #10 on: November 25, 2006, 03:46:50 AM »
It was the huge rear spring eye diameter that did me in, I had the spring eyes redone to accept the bush that came with Bills sliders, width wise the mono's were fine. Still tying to get the whole lot under the car, proving to be a real challenge on a car that already has the springs moved in, so far not a single thing is fitting, bolt in my ass.......
