November 23, 2008, 09:10:49 AM
| | |-+  under car painting
Author Topic: under car painting  (Read 548 times)
gasman
under car painting
« on: October 29, 2006, 06:20:20 PM »
There was a post at one time but I can't find it but I want to finish underneath and I am wondering what to use. What I thought about doing is painting things like K-Frame, rear end, ladder bar setup, and ect in a low gloss black and the rest, floor frame rails and tubs body color. What I am wondering is do I use an epoxy primer for best protection and what black should I use?
IF A GOATS A RAM AND A MULE'S AN ASS, WHY IS A RAM IN THE ASS A GOOSE?
eldubb440
Go Phillies!
eldubb440
Re: under car painting
« Reply #1 on: November 06, 2006, 09:32:02 PM »
magart
Cape Breton, Nova Scotia
« Reply #2 on: November 15, 2006, 08:01:12 AM »
Check out "caper's" ride in the member gallery...the underside of his dart is amazing....he'll be able to tell you what he did...if your results are half what his is, you'll be happy
automan63
« Reply #3 on: November 15, 2006, 11:22:24 PM »
I've had my Scamp sandblasted and I'm gonna paint the floor also, but with one exception, I'm going to use Spray Seam Sealer inside the fenders and rear wheel tubs, but it will also be painted over.
You can go to this link http://www.lordfulfillment.com/upload/UI3007.pdf
 or do a search for sprayable seam sealer and go from there. This method is very very stone resistant as the seam sealer goes on as thick as you want to put it on and is like a superball after it cures. Just m.h.o.  Jeff Undecided
automan63
« Reply #4 on: November 16, 2006, 08:06:28 PM »
Well, for the rest I'm just gonna paint and clear it just like the top side, with one exception.. I might use the PPG ceramic clear, or PPG's "anti-graffiti clear" they put that stuff on the outside of mass transit busses and trains. Tough as stone but huge money. Its a Polyurethane clear instead of just Acrylic urethane, very different curing and cross linking processes when they cure (dry). so, anything that happens to get stuck on the bottom of my car will just wash off, and at worst I might have to use some sort of spirit based cleaner, all the way up to and including lacquer thinner with no harm coming to the gloss and hold out. not even gas will hurt it! so the spray seam sealer is just for rock damage protection, more as a cushion from impact in direct line of fire from the tires. Hope this winded explanation helps you decide. I've actually done this before on a couple of Porsche repairs as thats what they do at the factory, no ceramic clear though, just spray seamsealer and paint. I'm not doing it everywhere cause I dont want to look at the roughness of it under the paint. The fenders I can live withcause I'd have to corkscrew my head in there to see it anyway same with the tubs.
eldubb440
Go Phillies!
eldubb440
« Reply #5 on: November 17, 2006, 12:01:47 AM »
automan,  agree  i posted kinda the same thing on the other thread ........i worked in a porsche shop also, back in the 80s and early 90s
