October 10, 2008, 08:34:16 PM
| | |-+  Mopar flip-top gas cap
Author Topic: Mopar flip-top gas cap  (Read 576 times)
Capt Jack
« on: November 06, 2006, 12:33:28 PM »
I managed to find a nice original mopar flip-top gas cap that I'm looking to use on my ride.  Ive seen a few grafted on to dusters and I think it'd lend itself well to the look Im after...
...however, its not a bolt-on install as I'd hoped.  it needs a little fab work/body work to make it fit without extending the tank fill tube or hogging out the backset surface thats there now to still allow correct function of the flip top and still seal the fill tube correctly.  shouldnt be much but thought I'd ask here and see if anyone has added one to theirs and see what issues they encountered or any ideas to keep this a clean and simple install.
thx in advance
CJ
qkcuda
Caledonia, ON Canada
Re: Mopar flip-top gas cap
« Reply #1 on: November 06, 2006, 01:30:51 PM »
There was an article in Mopar Muscle a couple of years ago where they put one on a 69 Dart.
Capt Jack
« Reply #2 on: November 06, 2006, 01:36:06 PM »
you dont happen to remember them encountering anything as far as retro fitting, do you?  I know I can make it work, but would hate to find out Im missing something simple and go about fabbing up things I dont need to.
« Reply #3 on: November 06, 2006, 01:41:40 PM »
The guy that put the quarters on Jeff's Dart spent some time trying to fit the flip gas cap from a 67 Barracuda onto the Dart. The problem is that there is an angle to the cap and none on the quarter of the Dart. I suspect the one in the magazine did not seal completely.
Capt Jack
« Reply #4 on: November 06, 2006, 01:47:16 PM »
precisely what Im encountering.  slight angles at the latch and hinge areas that need to be compensated for.   ok, then I'll just "adjust" the metal around the filler area slightly.  probably not a big deal, just dont want to hose up the paint in the process, but starting to think anything I'll do will require a little paint and body work, slight as it may be.  I just really want it to sit flush like its supposed to vs sitting on top like some dork just added it on with no forethought (ie: me)
thx
qkcuda
« Reply #5 on: November 06, 2006, 02:04:13 PM »
In the article he actually recessed it into the fender, a lot of cutting and welding. hammer
Capt Jack
« Reply #6 on: November 06, 2006, 02:11:11 PM »
hmm...really?  from test fitting and the like on mine I dont think it'll require extensive mods to get it to fit, just enough clearance to operate the cover...at least thats what Ive seen so far.   wouldnt be the first time I underestimated the work involved....hell, it wouldnt even be the first time I underestimated work involved today!   lol bash
maybe I'll hold off and make it part of my winter project.
qkcuda
« Reply #7 on: November 06, 2006, 03:18:41 PM »
He made a notch at the front for the hinge side to open, and a matching one at the rear for the button.
Capt Jack
« Reply #8 on: November 06, 2006, 03:31:40 PM »
yup.  same thing needed here.   ok, thanks.   at least Im headed in the right direction on this.  geez, and it seemed so simple. at the outset
Dart67
512 cu. in. EFI Jessieville, Arkansas
« Reply #9 on: November 06, 2006, 04:18:59 PM »
I used the complete setup from a 67 GTX. The cap, trim plate, and rubber adapter that goes between the cap and filler neck.
Works great.
To install, I removed the original cap, then the two Front filler tube screws. I used the cap as a template and drilled two small holes in the trim plate and used two 10x24x1/2" stainless steell machine screws and nylock nuts to fasten the cap to the trim plate. (there are two un-used holes in the cap). Then used the two holes in the cap that match the two filler holes that the screws were removed from and used (I think) 10x1" stainless phillps head sheetmeatl crews to scure the cap assembly to the filler tube, then drill one hole using center rear hole in the cap as a template and used one more screww to finish up.
Hope this helps.
Here's a couple of photo's:
Herb
          My 67 GT Convertible      340 mope's 67 Race Dart            My 67 270 Hardtop
Capt Jack
« Reply #10 on: November 06, 2006, 04:34:53 PM »
ah...therein lies the rub.  the trim plate.  after you said that I went and checked out a few of the ones on ebay.  one includes a trim plate that mine doesnt have.  I have the actual hinge & cap portion, but no trim ring.
http://cgi.ebay.com/ebaymotors/1969-BARRACUDA-MOPAR-FLIP-TOP-GAS-CAP-TRIM-RING-NR_W0QQitemZ160047202165QQihZ006QQcategoryZ140708QQrdZ1QQcmdZViewItem
thanks a ton for the pics and description.  I think I know what I need now.
qkcuda
« Reply #11 on: November 06, 2006, 04:49:41 PM »
The ad is a little misleading since 69 cudas didn't use a trim ring, but Chargers did. I think the cap Herb used may be different, since the GTX's were flat sided like the darts.
Capt Jack
« Reply #12 on: November 06, 2006, 05:10:09 PM »
yeah, but either way, I think I can get it to work fine sans trim ring.  at least I understand why it seems theres a piece missing.....cuz there is!
Dart67
« Reply #13 on: November 06, 2006, 05:12:07 PM »
qkcuda is correct, the 67 GTX is basicaly a flat panel like the Dart. I don't think the cuda or charger trim plates will work, but I may very well be wrong.
Herb
« Reply #14 on: November 06, 2006, 06:10:54 PM »
No trim plates on the Barracudas.
demon340v
« Reply #15 on: November 08, 2006, 12:23:45 PM »
I have a flip top from a Barracuda, that i was going to use on the Demon, so would the GTX style just be easier?
Capt Jack
« Reply #16 on: November 08, 2006, 12:58:46 PM »
from looking at mine, not that I can tell.
the trim ring in my case I think would actually add to the problem.
the filler neck top is very deep in the recessed area on the quarter panel on mine.  adding a trim ring to that would set the seal part of the cap even further away from the top of the fill neck.  what I'll need to do is actually clear out the recessed area to fit the base of the cap and clearance two small areas on either side for the latch and hinge parts of the cap to function correctly.
while adding a trim ring might let me get away without doing that last part, the cap itself would fail to seal the filler, requiring either lengthening the fill tube about 1/4 inch (or more) or making up for the extra distance in some other way.
I think I'll do without the trim ring myself.  from the looks of the ones Ive seen, they wouldnt really go with the overall look Im after anyway.
thebankerstoy
« Reply #17 on: November 09, 2006, 03:30:05 AM »
Jim is correct once again.  Grin The 69 Barracuda's used the same two parts as the 69 & 70 Charger's for the gas cap, but the Barracuda's did not use the base plate like the Charger's did. Here are the factory part numbers for those folks who are interested.
Part #2925878 - gas cap top piece. Fits 1969 Barracuda's and  Chargers's and 1970 Charger's WITHOUT the ECS emission control system. In 1969 & 1970, the word "FUEL" was cast on the cap. on the 1968 Charger's, it was just a plain cap without the word FUEL.
Part #2823339 - gas cap bottom piece. Fits 1969 Barracuda's and Charger's and 1970 Charger's  WITHOUT the ECS emission control system
Part #2880430 - gas cap base plate. Fits 1969 Charger's and 1970 Charger's WITHOUT the ECS emission control system
You can buy a re-poped cap, WITHOUT the base plate at various Mopar vendors for aroung $95.00 plus shipping.
Richard
mopar stu
« Reply #18 on: November 09, 2006, 10:12:11 AM »
or find a donor car and graft the whole  section in.
Capt Jack
« Reply #19 on: November 09, 2006, 11:22:38 AM »
or buy it on ebay like I did for $40.
Grin
mopar stu
« Reply #20 on: November 09, 2006, 11:27:01 AM »
40 bucks is sweet,was there any other bids? or were the pictures low quality which may have kept the bids low?sounds like you stole it.
loiq
« Reply #21 on: November 09, 2006, 11:30:01 AM »
Personally, I think Dusters (all A bodies for that matter) look best with no gas cap. Here's my old Duster:
Capt Jack
« Reply #22 on: November 09, 2006, 11:35:47 AM »
40 bucks is sweet,sounds like you stole it.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190038957464
yup, I think that about says it.   Evil
been watching these on ebay for quite awhile, stumbled across this one...boom.  its not 'show quality' but then...neither is the car.  now I just gotta make it work
dartracer
Strasburg CO.
« Reply #23 on: November 09, 2006, 03:18:41 PM »
I put one of those on my power wagon. I will see if ican get some pics when I get home.
thebankerstoy
« Reply #24 on: November 10, 2006, 09:33:46 AM »
$40.00 is a VERY good price for that gas cap, as I sold a complete 3 piece set at the Spring Fling car show / swap meet last April in CA for $75.00, but it was an original set from a 1970 Charger that was in excellent condition. I have another 3 piece set from a 70 Charger that is also in excellent condition, that just needs the black paint on the cap and base plate repainted to make it perfect, but I would not sell it for $40.00.  Tongue
Richard
dartracer
Strasburg CO.
« Reply #25 on: November 11, 2006, 07:31:41 PM »
Here are some pics of the one I put on my power wagon.
