October 10, 2008, 08:18:08 PM
| | |-+  what shocks
Author Topic: what shocks  (Read 539 times)
2815spd
what shocks
« on: November 14, 2006, 11:12:14 PM »
What shocks should I run with super stock springs on my  duster. It has a 281 cuin eng, nash 5 speed trans, and 6.17 gears with 28/10.5/15 slicks???
mopowers
Re: what shocks
« Reply #1 on: November 14, 2006, 11:39:38 PM »
Mopar Performance sells longer shocks for use with SS springs.  They are priced good too.  I've heard that Ford pick-up shocks will work also.  Not sure of the exact application or even if it is true.  I'm sure someone will chime.  By the look of the gear and trans you've got, it sounds like you got quite a hot rod, so you may want to go with a higher quality shock than a parts house unit though.
2006 Dakota
2815spd
Re: what shocks
« Reply #2 on: November 14, 2006, 11:49:30 PM »
Yeah, our local track runs heads up. My eng is a 318 bored to a 4.0 bore with a 2.800 stroke crank. The car weighs 3250 with me in it. This makes me a 11.5 lbs per cubic inch.
A13Dart
Minnesota
Re: what shocks
« Reply #3 on: November 15, 2006, 10:16:03 AM »
Rancho adjustable or Mopar Perf long shocks for stick shift A-body. Pinion snubber too.
