July 09, 2008, 04:59:30 AM
|-+  General Category
| |-+  Off-Topic
| | |-+  wont start - what is it?
Author Topic: wont start - what is it?  (Read 464 times)
bbscamp
Ehm.....B5 Blue am I?
« on: November 24, 2006, 04:41:16 PM »
The 73 S6 Dodge Dart Swinger wouldn't start using the ignition key.  You would have to put the key in the ON position, and jump out the starter to make it run.   By turning the key to start...nothing happened at all.   Question:  what do you think the problem is???
I found out problem....and it was fixed.  But What is your best guess on what the problem was?Huh    I post the answer a little later....
Hemi GTS
Yeah,its got a Hemi
Re: wont start - what is it?
« Reply #1 on: November 24, 2006, 04:46:36 PM »
Bad ignition switch.
bbscamp
« Reply #2 on: November 24, 2006, 04:58:02 PM »
Nope...strike one.
« Reply #3 on: November 24, 2006, 05:05:03 PM »
Broken wire from ignition switch to starter solenoid?
« Reply #4 on: November 24, 2006, 05:06:30 PM »
neutral safty?
GON_RACIN
Happiness is a warm gun.
« Reply #5 on: November 24, 2006, 05:07:25 PM »
i'll say bad starter relay.  If you try to crank it and the starter wont roll over....but your ignition circuit is HOT, 9 times out of 10 its the relay, especially if you can jump across the relay with a screwdriver and the starter will roll over.
DaBigNuttedMan
Leak it Lash it Pull it and Pipe it
« Reply #6 on: November 24, 2006, 05:07:38 PM »
starter relay on the firewall.  santa4
63' 330 Max clone, 68' Cuda 3/4" Strokr Hem, 18 pack Bud lite, no school, straight, F ,  F__K.      PIPE DA SHIT    IWMWW
DaBigNuttedMan
« Reply #7 on: November 24, 2006, 05:09:44 PM »
damm goin racin beat me to it [I'll use el dubs emoticon
« Reply #8 on: November 24, 2006, 05:12:09 PM »
too obvious
bbscamp
« Reply #9 on: November 24, 2006, 05:24:24 PM »
Ignition switch good, relay good, NS switch good, starter good, no broken wire er.......well OK....it was a broken wire.
Some how, some way some broke  the wire to the neutral safety switch.  It alway thought it was in gear.....
Good guesses boys!
71 demon child
« Reply #10 on: November 24, 2006, 05:26:00 PM »
Starter Selenoid. bat
taking donations
71 demon child
« Reply #11 on: November 24, 2006, 05:27:10 PM »
Aww damn! I didn't even see the answer in front of me. hammer
taking donations
« Reply #12 on: November 24, 2006, 05:28:42 PM »
Good guesses boys!
for english, press 1 lol bash.....i win  drinks
71 demon child
« Reply #13 on: November 24, 2006, 05:33:57 PM »
Good guesses boys!
You're a Butthead.No...Wait a minute.You're a B )(/*eavis
taking donations
DART VADER
« Reply #14 on: November 24, 2006, 05:45:47 PM »
Maybe its a flat tire. lol bash lol bash lol bash
bbd sign tried and true
440Ken
You got a 440 in that? Spring Hill, FL
« Reply #15 on: November 25, 2006, 04:33:16 AM »
Check air pressure in spare LOL LOL. There were all great for the ballast resistor causing start problems.
