Topic: K-frame,it's a little hacked on (Read 565 times)
Westernstar
If you have a moment tell me what you think.I just pulled the Caddy motor out of my Dart and can now see the hack job on my K-frame.There are two good sized holes as you can see on the top and the bottom.I can do a real good repair on that.Now if you will notice on your right,i put a piece of paper under it for contrast the drivers side motor mount tower has a brace that was hacked on, i can repair that.My question is this.Is there anything missing in this area due to the fact there was a Caddy motor in it? Do you think the integrity of the piece has been comprimised? Thanks for any input. Neil.
jet-taz
you could weld them up ,but for time and effort,i would buy another. k-frames are out there.
Online
That brace under the left side mount is original. I can't really tell what they hacked out of the right side. The only early (67-72) small block k-member I have is under my 340 so it's hard to see what is where.
ski
On the driver side you'll have to sacrifice part of the original pad mount anyway. That mount is still clear in your pic. The pass. side looks to be missing. You can't make a DC member out of it. I believe it's also too buggered to go to Shumacher's for a bolt in. Like jet-taz said . There's a bunch of them out there
 Yep, found my '73 - '76 V-8 K member for $100 locally and made the DC peice per Jim's article in the tech pages.  Relocated mounts; ignore the cow catcher on the bottom.
vitamindart
i could have used that cow catcher the other day when i smacked the pan on a crappy street repair job
Ouch. Its about 3 1/2" deep and 1/2" deeper than the Milodon 7 qt pan. Tom
acpat
cowcatcher  Fear not wait till you rip off a pan. I like it and it gives piece of mind I am sure
jamesdart
tom how did you clean that K frame? it almost looks like it was dipped?
Nothine cleanes quite like methalene chloride. Seriously, go to Home Depot and get some Jasco. Jasco will stip paint, bondo and even powdercoating. It is about $15 per quart. After it sits for about 20 just wash off with a hose. Make sure you wear rubber gloves. I strip everything with it. Paint it on with a natural fiber brush. You can watch the paint bubble within seconds. Also, it helps to have nice pristine rust / salt free metal from the Seattle area.
BIGFISH
Nothine cleanes quite like methaline chloride. Seriously, go to Home Depot and get some Jasco. Jasco will stip paint, bondo and even powdercoating. It is about $15 per quart. After it sits for about 20 just wash off with a hose. Make sure you wear rubber gloves. I strip everything with it. Paint it on with a natural fiber brush. You can watch the paint bubble within seconds. Also, it helps to have nice pristine rust / salt free metal from the Seattle area.  Good tip, thanks. santa4
'64 Barracuda, 360, 4spd, 8-3/4.....lots of stuff done, but alot still to do
elliskev2
I was thinking the same thing - Wow
