July 23, 2008, 06:06:14 PM
|-+  General Category
| |-+  Off-Topic
| | |-+  welder help
Author Topic: welder help  (Read 336 times)
smitty72
I'll finish it someday
welder help
« on: November 25, 2006, 05:47:49 PM »
question for mig welders. what causes the wire to twist up were it feeds into the gun hose? do I just not have the thing adjusted right,  I havent really played with adjusting this thing but I had no problems when I welded the quarters on last month but when I was putting the patch panels in the floor I had to refeed the wirte like 6 times.
its a hobart 140
thanks for hte help Smitty
71 demon child
Re: welder help
« Reply #1 on: November 25, 2006, 06:13:58 PM »
You didn't happen to run over or drop something on the hose itself?The liner could be damaged and it's snagging the inside of the liner and the wheel just keeps feeding it causing it to bird nest.Other than that,i'm not sure.I'm sure Tom can tell you more.
carl
taking donations
Ed
Phoenix, Az
Re: welder help
« Reply #2 on: November 25, 2006, 06:25:45 PM »
I had the same problem (and the same welder), but it was only with one roll of wire.  So I figured it was something wrong with the roll.   Make sure the that feed roller inside the welder is set up for the right size wire, I noticed it's real picky about that and won't feed right if it's not right.
formerly VIN_VL29U
TimH
Re: welder help
« Reply #3 on: November 25, 2006, 07:14:36 PM »
Some cheap rolls are not wound evenly. You'll find more expensive wire, such as Lincon, is wound nicer. Try increasing the drag on the spindle that holds the roll of wire.
Tim
smitty72
Re: welder help
« Reply #4 on: November 25, 2006, 08:45:45 PM »
I've tried changeing the tip, its either the spool of wire or the hose,\ I think that it could be the hose it feels like it is dragging the wire close to the top when I feed the wire.
thanks
dangerdawg
Re: welder help
« Reply #5 on: November 26, 2006, 10:15:56 AM »
liner size match the wire size?
eldubb440
eldubb440
Re: welder help
« Reply #6 on: November 26, 2006, 10:37:54 AM »
i had a problem when my wire got a little rusty.........i peeled off a couple layers and everything was fine.
bentwheel43
Re: welder help
« Reply #7 on: November 26, 2006, 11:52:47 AM »
 The defuser (thats the part that the tip screws in) came undone from the liner or the liner is to short,all at takes is rolling the whip on the welder handle or keep twisting the gun. The defuser should be fasten to the liner with small allen head screws. When it comes lose the wire will spin and if the tip is wornout it can spin the wire some too.  Now if you talking about birdnesting the wire, the liner mite be bad or twisted or a bad tip.Make sure your liner is strait. The wire must be clean with no rust.     Bent43
section 8 racing , we're nuts about racing"""'
smitty72
Re: welder help
« Reply #8 on: November 26, 2006, 05:16:24 PM »
the defuser did come off the gun when I changed the tip . I will have to take a look at it and see if I can get it back to the way it is supposed to be. thanks
