July 06, 2008, 02:21:33 PM
|-+  General Category
| |-+  Off-Topic
| | |-+  68 super bee fender tag lynch rd plant
Author Topic: 68 super bee fender tag lynch rd plant  (Read 359 times)
silk
« on: November 29, 2006, 09:09:58 AM »
anbody interpet these code  2nd line down      r has a 1 under it    x has a 2 under it   y has a 7 under it   next line down is numbers 1 thru 8  under2 is a 5   under4 is a 7 under 7 is a 8   axle 4    trim h4r  paint rr1     next is ucs u has r under it and s has a 7 under it    .bottom line     wm21   62    5        44         522        2888106
Ed
Phoenix, Az
Re: 68 super bee fender tag lynch rd plant
« Reply #1 on: November 29, 2006, 11:14:00 AM »
I'll give it a shot, from bottom to top
WM21= Coronet Super Bee 2-Door Sedan (post car)
62= 383 4 Barrel Carb
5= 3 speed automatic
44= should equal tire code, but don't know for sure or what it is
522= SON (shipping order number)= May 22 =production date
2888106= Production Sequence
The UCS code can be a pain to decode:
U=upper door frame R =Burgundy Metallic
S= Stripe= accent stripes = 7=? not sure
The numbers under 12345678
are the drip, b-piller and wheel opening mouldings (has chrome)
Axle code ?
Trim= Red Interior
Paint= Burgundy Metallic (color of the car top and body=double RR)
formerly VIN_VL29U
silk
« Reply #2 on: November 29, 2006, 06:50:42 PM »
Thanks ed  so if this bee had power brakes or ps would it have showed up on the fender tag
Ed
Phoenix, Az
« Reply #3 on: November 29, 2006, 07:15:59 PM »
Only on the broadcast sheet.  So if you can find that, it will tell you everything the car came with.  Ma mopar sold a lot of no thrills (no power options) cars back in the day.   The automatic trans might be the only option on the whole car, only the broadcast sheet knows for sure.   Helps if you know the history of the car if you don't have the broadcast sheet, things like if it was a drag car, guys take off the pb and ps.
formerly VIN_VL29U
