October 11, 2008, 03:21:05 AM
| | |-+  Manual Disk brakes?
Author Topic: Manual Disk brakes?  (Read 802 times)
joesnow
s.e.pa.
Manual Disk brakes?
« on: December 04, 2006, 06:23:24 PM »
This might seam like a dumb question \/][ thank you, But can the disk 1973 setup be used as a manual without the boaster? What master to use? Thanks.
Capt Jack
Re: Manual Disk brakes?
« Reply #1 on: December 04, 2006, 06:35:47 PM »
mine ('73 Duster) is manual disc front as well as an original factory MC...but not for long.  they work fine
mopowers
« Reply #2 on: December 04, 2006, 06:38:05 PM »
Yes, it will work very well.  You can either use the stock non-power duel reservoir master, or buy or make a two bolt adapter and use a later model master from say a '85 diplomat.
http://www.bigblockdart.com/techpages/mcadapter.shtml
https://www.reillymotorsports.com/store/product.php?productid=16148&cat=257&page=1
2006 Dakota
atomicDog
« Reply #3 on: December 04, 2006, 07:52:44 PM »
I've done this swap several times.  When I do, I get Pep Boys to order a Reybestos manual disc brake master cylinder for a 1973 Dodge Charger.  I love manual disc brakes on these cars, as they stop great with not much pedal effort.  IMHO, no need for power disc brakes on these light cars, especially if the motor has a long duration camshaft.
joesnow
s.e.pa.
« Reply #4 on: December 04, 2006, 10:14:05 PM »
Thanks. I wanted disk, but don't want the boaster in the way.
« Reply #5 on: December 04, 2006, 10:39:58 PM »
Yep, no need for power brakes.
moparrr07
working on custom console
« Reply #6 on: December 04, 2006, 10:42:53 PM »
manual disk are about 5 time easier to push then manual drums on my car, and i think power brakes wouldn't give you as "real" of a feel
brakes, 11 3/4
60-0: 105 ft.
cornering gs: estimate: .90
50% custom interior
gsmagnum
« Reply #7 on: December 04, 2006, 11:36:42 PM »
To get the later style master cylinder, you can get one for a 1980 Volare/Aspen with manual discs.
I had one that had manual discs and they worked great.
I didn't realize they were manual for 'til one day when I was adding tranny fluid and actually happened to look.
guzzimike
1968 Dart GT (383)
« Reply #8 on: December 05, 2006, 01:14:50 AM »
74DDS
Lakeville/Mankato, Mn
« Reply #9 on: December 05, 2006, 02:25:50 AM »
i just took my booster out and got a new adjustable pushrod, everything works fine
Lars
ATX
« Reply #10 on: December 05, 2006, 02:57:28 AM »
Yeah the manuals work great. My 73 has a MC from an 85 Dippy, stops real good.
65dart440pro
« Reply #11 on: December 06, 2006, 02:51:34 AM »
I had factory manual front disc brakes on my 1965 Valiant. They worked great. 4 speed drag tree 4 speed
1965 Dart 440/727 & some big A$$ tires!
www.myspace.com/pro65dart440
cb
« Reply #12 on: December 06, 2006, 07:21:58 PM »
So guys  Humor a newbie here, pease
If I get Kesley Hayes calipers and new rotors etrc.  what else do I need   (ALL PARTS PLEASE) to conert my drums to manual discs.
I have the 5 x 4 sbc and would like to keep it.
74DDS
« Reply #13 on: December 06, 2006, 10:13:25 PM »
Well I don't know if you can keep the small bolt pattern with disks, plus why would you, there are so many more choices of rims with the bigger bolt pattern. To convert it you'll need the spindles off a disk brake car, now what i don't know is if there diffrent ball joint to go along wtih the diffrent spindle. I know somebody here will chime in with the correct answer.
cb
« Reply #14 on: December 07, 2006, 01:38:58 PM »
BUMP  any real answeres here?
magicinkc
« Reply #15 on: December 07, 2006, 07:38:22 PM »
I think you will only need to get the spindles,rotors,calipers,caliper adapters,and assorted bearings. Grin   drinks
The only problem I know of is, I have heard the spindles and the rotors are hard to find
magart
Cape Breton, Nova Scotia
« Reply #16 on: December 08, 2006, 08:28:44 AM »
I spent years trying to get rid of the sbc and my 9" drums..I would have settled for the sbc discs, but everyone told me the rotors are very rare AND expensive...finally found what I need to convert to 5x4.5 discs......you will also need to change spindles, and upper control arms...the donor car for these pieces will most likely have the 5x4.5 bolt circle, so as others have said..you're better off to upgrade(of course then you're into axles...like me!!!...more$$$)
joesnow
s.e.pa.
« Reply #17 on: December 08, 2006, 09:52:42 PM »
Check at slantsix.org  I know my brothin-law wants to keep the sbp  hammer He say there is a cheap way to do it with chevy caviler parts and 1 after market. You keep yopu spindle, some kind of caliper bracket, and cheap rotors drilled to sbp.  ask   70'valiant at slantsix.org Smiley
moparrr07
« Reply #18 on: December 09, 2006, 11:50:51 AM »
it explains it all in the tech pages,
the rim choices are so much bigger for 4.5 bc
brakes, 11 3/4
60-0: 105 ft.
50% custom interior
Rare_TA
« Reply #19 on: December 10, 2006, 01:01:56 PM »
The ones I've done I get the master cyl from NAPA. It's number 10-1515 and costs about $20.00 for the rebuilt unit.
70 Challenger T/A 340 727
68 Road Runner 383 4 Spd
68 Dart 270 going to be 360 727
HTTP://freiss.co.nr
74DDS
« Reply #20 on: December 13, 2006, 05:03:34 AM »
I guess the way I've herd for getting BBP disks and such is to go find a latter model dart,duster,dart, sport or what have you that has disk brakes and basicly take the front end and swap it with yours, ie spindles, control arms, and such, I can't say exactly because my Dart Sport came with them.
