December 03, 2008, 12:54:32 AM
| | |-+  ground clearance
Author Topic: ground clearance  (Read 435 times)
496dart
ground clearance
« on: December 09, 2006, 03:53:38 AM »
hey guys, i have a 70 dart with BB and Moroso 7 qt pan . Looking under the car, there is not very much ground clearance to the pan.  What can be done to remedy this?   If i tighten up the tortion bars will the motor rise?  or just the body ?
69 GTS Clonvertible
GEAR+SLAMMER
Re: ground clearance
« Reply #1 on: December 09, 2006, 04:01:49 AM »
the whole front end. You may try the remote oil pan set-up with pump to remedy this. I believe they use this set up in nascar. Someone on the bored must know what I'm refering to.
496dart
« Reply #2 on: December 09, 2006, 04:05:25 AM »
so tightening the t -bars will give me more pan to ground clearance?
69 GTS Clonvertible
GEAR+SLAMMER
« Reply #3 on: December 09, 2006, 04:07:02 AM »
yes it will but it will also cause sterability problems and tire wear.
496dart
« Reply #4 on: December 09, 2006, 04:15:53 AM »
Oh well, its not going to get a lot of miles on it.  Id rather have those problems than smashing my pan on something . Grin
69 GTS Clonvertible
GEAR+SLAMMER
« Reply #5 on: December 09, 2006, 04:24:51 AM »
weld a skid plate onto the k-frame like Tom did (B569RR)
Dartsport
« Reply #6 on: December 09, 2006, 07:45:32 AM »
If you raise the front end , get the front end aligned again.
slow_motion
Truckville, the capital NY
« Reply #7 on: December 09, 2006, 08:55:51 AM »
Yes, you should get it aligned again, after playing with these cars for years, sometines a change in ride height has a dramatic change on the way the car handles----sometimes for the worse---i know--the hard way.
Anyhow, i have gotton away with as little as 2.5" from the pan to the ground, with the K-frame being just a touch lower than a standard type floor jack (maybe about 3.5-4" from the ground). The streets around here are fairly good, if i was going over the the main drag of town where i live now, i wouldnt go that low however. Its a fine balance of what looks good and what clears the road obstecles. I hope my measurements give you a point of reference though, and when you get it set at what you like, get that alignment done so it'll handle straight and proper.
--chad
'95 Ram, her truck
'20 Model T pickup, stock
« Reply #8 on: December 09, 2006, 10:40:08 AM »
I dropped the Front end of the RR to give it a little rake. Just had to get it realigned. The floor jack barely fits but I also have heavy 1.16 bars.
This is the road turtle remover that clonvertible is referring to. It is about 1/2" lower than the Milodon 7 qt. pan. I will be bolting it on today.
I had a freind that had his drain plug ripped out while driving around town and figured I'd box mine in.
B1Valiant
« Reply #9 on: December 09, 2006, 11:57:09 AM »
Well here are a few suggestions. You could as already stated raise the T bars. Option two you could run a taller front tire. Option three, if you run an engine plate you could run some K member spacers. like the 68 Hemi A bodies do. Or you could combine any of the three and gain ground clearance. BTW if it matters mine is only about 2.5" off the ground, I just try to be careful. If it is a street car a skid plate might also be a good idea.
BTW B65RR nice looking welds...
496dart
« Reply #10 on: December 10, 2006, 09:15:53 PM »
Thanks--im going to jack up the T bars and try that. The tires are already mounted and on the car, i dont want to change those . 165/15 size . 15x4 Weld rims.
DartKnight
« Reply #11 on: December 10, 2006, 11:10:20 PM »
It'll be easier on your headers, too; if you're running full-length...
Jason
