November 20, 2008, 07:26:10 PM
| | |-+  SHOW ME YOUR MSD IGNITION BOX LOCATION?
Author Topic: SHOW ME YOUR MSD IGNITION BOX LOCATION?  (Read 1361 times)
69 GTS Clonvertible
GEAR+SLAMMER
« on: December 09, 2006, 03:00:56 PM »
I'm getting ready to install my MSD 6AL ignition box and would like to see where you guys installed yours, Im thinking on the passenger side inner fender or under the dash and heater box on the passenger side. What do you think?
Thanks,
Shawn santa4
73swinger
Blackstock, Ontario
Re: SHOW ME YOUR MSD IGNITION BOX LOCATION?
« Reply #1 on: December 09, 2006, 06:04:24 PM »
well, i didn't really wanna put it there, but i wanted to extend the wires even less. I see alot of them installed  in this manner. It was very easy to access the bottoms of the holes
69 GTS Clonvertible
GEAR+SLAMMER
« Reply #2 on: December 09, 2006, 11:28:17 PM »
73swinger,
Wow I can barely see it in that small pic. Do you have all the wires running toward and along the fire wall?
73swinger
Blackstock, Ontario
« Reply #3 on: December 09, 2006, 11:46:15 PM »
ya , sorry for the pic. I had to resize it and my program is kinda screwy. The wires all run back towards the fire wall and tie into the harness there, this one's better
69 GTS Clonvertible
GEAR+SLAMMER
« Reply #4 on: December 10, 2006, 01:13:57 AM »
73swinger,
Do you have any issues with your blaster 2 coil being on its side? I keep reading that they are supposed to be vertical and not horizantal. I currently have mine laying on its side but I have not used it yet. From what I've been reading is that the coil does will heat up and have problems cooling itself because it is an oil filled coil. I think I'm going to relocate mine to the passenger side inner fender up by my horns somewhere to keep the thing from crapping out.
Thanks for the larger pics the really helped. santa4
73swinger
Blackstock, Ontario
« Reply #5 on: December 10, 2006, 10:43:52 AM »
Well to be honest, mine hasn't been fired yet either. I'm still waiting until i put the new driveshaft in, right now there's no slip yoke in the transmission, no exhaust either (but I'm not opposed to firing it with open headers). I really never heard that laying it on its side could be a problem, I just used the factory location. I know I've seen quite a few cars with it there.
ANYONE ELSE COMMENT ON THAT?Huh
« Reply #6 on: December 10, 2006, 01:22:17 PM »
It will fit under the dash between the ash tray and the glove box.  You'll have to move the flasher but that's really nothing.  Two bolts down through the bottom of the dash and it's in there, tucked away and invisible.
1968 Dart GT (383)
« Reply #7 on: December 10, 2006, 04:37:39 PM »
Our MSD6AL is installed almost exactly in the same location as the one in the pics above. Our Blaster 2 coil is likewise side-mounted on the standard location on our Performer RPM manifold.. It has been like this for over 3 months of daily driving, with all of the starts/stops that this entails..and we have had no problems...
I was not aware about the vertical mount preference for oil filled coils.
55robert@comcast.net
« Reply #8 on: December 10, 2006, 05:25:09 PM »
my msd 7al-2 is under the dash in a 69 boss 351 cleveland mustang in north carolina. seriously through, heat is the #1 killer of a msd or any electronics for that matter. sticking it under the fender is far better than in the engine compartment, but when i had the 7al-2 it was where the heater used to hang out.
6469mopar
JACKSON, NJ
« Reply #9 on: December 10, 2006, 07:36:01 PM »
here's mine (  pics ) santa3
« Reply #10 on: December 10, 2006, 09:02:30 PM »
and get your coil off the motor.
73swinger
Blackstock, Ontario
« Reply #11 on: December 10, 2006, 10:35:38 PM »
Ok seriously, HOW IMPORTANT IS THE COIL LOCATION?Huh? The factory put them here and they ran fine for years. Is the MSD coil really that much more sensitive??
1968 Dart GT (383)
« Reply #12 on: December 10, 2006, 11:12:47 PM »
Exactly. I am wondering the same thing. OEM coils lasted for years living on their engine manifold mount. Is the MSD Blaster 2 coil that much more fragile..?
farmington
Metro Detroit
« Reply #13 on: December 10, 2006, 11:21:02 PM »
I've been in this hobby for over 35 years and I've never heard anything about not laying a coil on its side.  When I bought my MSD coil there wasn't anything in their instructions either.
When in doubt, Whip it out!
« Reply #14 on: December 10, 2006, 11:36:17 PM »
remember the heat thing, they will perform much better.
69 GTS Clonvertible
GEAR+SLAMMER
« Reply #15 on: December 11, 2006, 12:33:17 AM »
Here is the install instructions that came with my MSD Blaster 2 coil, it also mentions this in the MSD 6AL instructions, and if you go to the MSD web site it also has a frequently asked questions type of information that also says to mount in a vertical position and to keep away from heat.
69 GTS Clonvertible
GEAR+SLAMMER
« Reply #16 on: December 11, 2006, 12:39:34 AM »
73swinger, I also read in the MSD 6AL install instructions that the purple and green distributor trigger wires should not be ran seperate from the other wires off of the box, so you may want to rethink that and run them up toward the front of your car and then across to the dist.
1968 Dart GT (383)
« Reply #17 on: December 11, 2006, 01:23:09 AM »
Well, it looks as if the MSD Blaster 2 coil should NOT be mounted horizontally. This coil is oil cooled,and there is an air bubble space in the oil in the coil. If the coil is mounted horizontally, the air bubble may cause part of the coil's windings to be exposed Above the cooling oil, and this could cause the coil to overheat and fail, especially if used in conjunction with an MSD electronic ignition (so sez the MSD website FAQs)
To remedy this, either re-mount the coil horizontally, or get a MSD High Vibration Coil (pn 8222), where coil mounting position is inconsequential.
http://www.msdignition.com/coil_blaster_3_8222.htm
I will be ordering a High Vibration Coil for myself. They are only $45.00 from Summit or Jegs, and for the money, I think it's worth the peace of mind of not having to worry If I already damaged my existing Blaster 2 coil to the point of certain upcoming failure..And besides, the Epoxy-Encased Windings construction of the High Vibration coil can only be beneficial considering that our engine has a fairly rough idle compared to most cars out there.
PinkE
A New Journey Begins.....
« Reply #18 on: December 11, 2006, 07:21:09 AM »
To keep the stock look under my hood mine is installed under my battery tray, you can't really see it unless your looking for it.  It's been mounted there for over 10 years with no problems....
« Reply #19 on: December 11, 2006, 07:51:52 AM »
That's a great idea. I also wanted to hide it for factory appearance. Mine is mounted to the face of the heater box on the RR. The Mopar box is to the right of the HI-6 box for backup. The remote CD player is under the heater box. I will be doing something similar with the Dart.
PlymanNos
BAD TO THE BONE
« Reply #20 on: December 11, 2006, 08:48:52 AM »
This is an old picture before I went to the Mopar black 6al but it is in the same place.
Bill,
"Mid 9'S IN STREET TRIM"
« Reply #21 on: December 11, 2006, 10:48:30 AM »
your right pinkE, i can't see and i looked for it.  \/][
demon340v
« Reply #22 on: December 11, 2006, 03:13:55 PM »
i was going to mount my under my battery tray BUT!  they don't reccomend mounting them upside so i was like crap!
So instead when i relcoated my battery to the trunk, i  mounted my MSD box right there on it's side and i run the wires along with my wires for my starter relay.
73swinger
Blackstock, Ontario
« Reply #23 on: December 11, 2006, 07:19:18 PM »
 \/][ just when i thought my engine bay was all wired up looking nice. I know it said to keep the purple/green wires seperate but it's got that rubber sleeve on it and I double insulated the other wires before I attached that one to the bundle. I suppose an induced voltage could affect it, but i think I'll wait and see. As far as the coil goes, If a high vibe one is only $45 I'll blow this one up right where it is thank you, then replace it with the right one. I know .....I'm really stubborn. Maybe I'll look at relocating it, let you know
74DDS
Lakeville/Mankato, Mn
« Reply #24 on: December 19, 2006, 02:41:31 AM »
Hey PlymanNos, is there any real diffrence in performance between the MSD and mopar boxes? I've seen that the mopar one is cheaper, and I was wondering if there was any trade off with the cheaper one.
PlymanNos
BAD TO THE BONE
« Reply #25 on: December 19, 2006, 11:12:35 AM »
It's a 6 AL box wrapped in black. It is hooked up the same and performs the same.
Bill,
69 GTS Clonvertible
GEAR+SLAMMER
« Reply #26 on: December 19, 2006, 10:21:04 PM »
That is a hell of a wicked pic ^ you have there PlymanNos. Evil Grin
1968 Dart GT (383)
« Reply #27 on: December 19, 2006, 10:41:33 PM »
Bill,
Agreed. That's what I have, the MOPAR (6AL) black-box.
Hotwheelsjr
Mike - Surface Of The Sun, AZ
« Reply #28 on: December 22, 2006, 07:03:28 AM »
I'm glad I saw this thread...my Blaster 2 is on the back of the intake, like stock ones.  Now I have to think about relocating it... hammer  My 6AL is on the DS inner fender...
Brad4406
« Reply #29 on: December 28, 2006, 11:20:03 PM »
I mounted my box under the passenger seat so when I open the passenger side fresh air door it blows right down on it.  I mounted my blaster II coil on the passenger side inner fender near the alternator so it would be forward of the headers and get a llttle less heat.  Sorry I don't have pics, I'm not in the states any more.
Brad4406
brawn4406@yahoo.com
Pages: [1] 2  All Go Up Print
