December 03, 2008, 12:57:24 AM
| | |-+  Wing window frame removel
Author Topic: Wing window frame removel  (Read 226 times)
Duskybird
« on: December 11, 2006, 03:02:00 PM »
As the title says, How do you remove the wing window frame? I have gotten the two big nut/bolts removed. The issue is where the window pivots it seems to be bolted in but I cant find anything.
Thanks.
Re: Wing window frame removel
« Reply #1 on: December 11, 2006, 04:56:29 PM »
The roll up glass needs to come with it and the weatherstripping must be removed, which will destroy it. It is available new.
valiant451
« Reply #2 on: December 12, 2006, 10:01:12 PM »
IF YOU LOOK VERY CLOSE YOU WILL SEE A VERY SMALL PLASTIC PLUG STRAIGHT ON THE INSIDE DOOR PANEL. POP IT OUT THEN THERE WILL BE AN ALLEN SCREW JUST UNDERNEITH.
Duskybird
« Reply #3 on: December 14, 2006, 05:35:09 PM »
Thanks! That's what was holding me up.
