Topic: ray barton (Read 1297 times)
outlawdemon
has anybody have any problems with ray barton,i ordered a kb hemi block 6 months ago and it still not here,i been taking to craig there for more then a month to see where it is.he says it on route from kb.he said he will call me back when he gets more info on where it is.two weeks later,i called him back .he tould me its in route.now two weeks later i called kb to day,he said they arnt sending them any blocks.they didnt pay the bill.so now i got to try to get my 2500 depost back and call kb and order a nother block and wait 10 more weeks for it.also i am still been waiting for my stage 5 heads.its been 3 or more months now.i just orderd a oil pan and oil systen 2 weeks ago.but they sent me there intake on time.i would like to get there rocker system.but not shore if i can trust them. we will see if i get my other parts first.and i will call ray barton tommrow to ask why they lied to me.so i dont recamend them!
Bigcube
All I can say is my 6 week job on my heads took 3 months. They swapped my springs but didn't know what they put on. I had tested my springs before I sent them the heads and they were fine as far as pressure but I didn't know if they would clear the extra lift. I said, change them if you have to because you are changing the cam... but If mine will clear the extra lift, use them. Well when I got the heads back, the springs were changed, but they didn't charge me for them because Craig said mine were fine, we used yours... It was like pulling teeeth to convince him my springs had a gold stripe and the springs on my heads have an orange strip. ![\/][](http://www.bigblockdart.com/Smileys/classic/finger020.gif) I aslo requested all my parts back, valves, keepers, retainers and never got them. It took weeks to get the before/after flow numbers and the numbers were not consistant with a few other benches. So my opinion is unless you are buying a 50k super stock motor, there are plenty of other good builders out there that will treat you with respect and not give you the run around on when they will complete your work for you.
Jim  Yes it's fast and no you can't drive it! Best 1/8 1.259 60', 5.67@121 Best 1/4 8.94@151 All Motor http://www.bigcube.org/
1meanfish
I've never dealt with them but I havn't heard anything bad about them either. You have a right to be ticked off, I hate getting jerked around. I'm sure they'll refund your deposit once you start bitching. Keep us updated.
outlawdemon
if they dont refund my money back,i only live a hour away and then there will be problems!
lead foot dan
Sounds like you need to deal with some new people like indy or muscle motors or bischoff fast times did my motor and dealt with b-1 direct great people
fasttcars
well i have to say one bad thing about INDY....i ordered a std bore..aluminum hemi block.....and at the same time ordered my custom pistons......so got the block 500$ shipping....anyways pistons came around same time......YA they sent me a F%^&Ing 0.120 bigger block then what i asked for....i call them and i'm like wtf...so they tell me they have no records of it being a std bore block.....thanks guys.....so i tell them since you guys fuk ed up and didn't write down the correct info...i want them to pay shipping on returning the pistons i already got,about 100$.....i talked to them like 7 different times each time same old story....we don't have records of what it was suppose to be.......ya that's the problem thanks assholes.......anyways
chryco
I`ve spoken to Craig a few times and got promises and of course no action on a couple of occasions. I was going to get a complete set of gaskets for my motor through them (copper head , intake etc) all the similar thickness as type as whats in the motor for future teardowns . Although they should have all that info on file, I think I`m going to source this stuff direct from the vendors, might be less hassle. Sad situation , hopefully everythings going OK over there hate to hear things like this about a former hometown boy like Ray. You sure don`t hear much about how their car is doing in S/S for the past year or so. Chryco  P.S. My engine came from RBRE , I have great faith in the way it was built and parts used and so far am super happy with it. [attachment deleted by admin]
Hemi Darts Rule !!!!!
uwee440
My motor came from Ray Barton,I can't say anything bad about him,he builds excellent motors.
Ray Barton Racing Engines
mopardude318
i had my 408 built by dave at hughes engines....just got it a few weeks ago, im very happy with his work, awesome customer service...
1970 Dodge Dart, 408 sb, eddy heads, 4 spd, alterktion, 8 3/4
Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax. - David Charles Gedraitis
4SPEEDDON
I JUST GOT SOME 408 STROKER PARTS FROM DAVE AT HUGHES MYSELF.THEY WILL HELP YOU OUT EVERY STEP OF THE WAY IF YOU NEED IT.I ALSO WORK PART TIME AT AN ENGINE SHOP HERE IN RHODE ISLAND WERE MY 408 IS COMING TOGETHER.
1meanfish
 I've worked with Hughes Engines on a number of occasions and they are very good with customer service and handling problems in my experience with them.
Wicked70dart
I just ordered hughes cam and complete valve train package, rockers and timing chain. Talked to kent had questions he was unsure of, so he let me talk to dave, he took the time to answer all my questions. Very happy with their customer service. Matt
jimmyb
I will say that they SUCK as far as costomer service.I worked on buying a blown hemi from them and kept getting the run around from Craig. I went a annother route.
 Blown 572 Hemi Work in progrees Engine by Dram
lead foot dan
Everybody has problems sometimes i was with fast times for years and still had problems....
drew54
I hate to tell you this, but you'll probably be waiting more than 10 weeks for that KB block. I ordered mine from them about two months ago and I haven't even come up on the list. Probably another 6-8 weeks after your name comes up from what I hear. Hurry up and wait is the theme when it comes to hemi parts. Somehow got the stage v heads shipped to modern cyl head in like a week. I think Jeff at modern may have an inside track on them. Good luck.
Drew
318_Magnum
Drew
So I hear. The Hemi stuff is all in very high demand now, but the output isn't really increasing so the wait times on them are killer. Someone on another website had the right idea and suggested that "if you're going to Hemi-fy your car, put your down payment in way before the car is ready for the motor, so by the time the rest of it's done you'll only have to wait a couple months for it!"
 '99 Dakota Sport: 318 Magnum/NV3500/9-1/4 '72 Demon: 340/727/8-3/4 '69 Barracuda Fastback: 400/727/Dana 60 Proj. '76 Dart Sport: 360/904/8-3/4 Proj.
lead foot dan
Had a kb block in my car had problems keeping a couple cylinders cool on heavy spray... watch number 5 if spraying alot had better luck with fogger..
outlawdemon
my block is a street hemi water block,i hope it dont get hot.i am going to be running 2 big gt55-88 turbos on my set up,and so far i havent got a hold of craig,he is supposed to call me back tommrow.i got a hold of jason,he said he would relay my message.
fasttcars
no the stock blocks never had an cooling issue even when 3/4 filled with cement....
outlawdemon
its not steal street hemi,its a aluminum kb hemi block
fasttcars
oh ya...i should have read that.....for the kb block i would look into that more because i was talking to a few guys regarding streetability and they said even though the block passe's water it's not very efficient at cooling like the old stage4 block's....so you could potentially run into problem's without some mods...
lead foot dan
It was aluminun water block look into the msd digital 7 you can program individual timing per cylinder
tweety
I WAS ( repeat was) a long time customer and support of Mr. Barton's organization and for reasons I won't go into on this public forum I will no longer give them my business, the saleman there - Craig lacks any credibility with me for either customer service or product knowledge. and Mr. Barton's financial practices leave much to be desired. The good news is Outlaw that Dennis was on the phone with me last night with me and it seems that your money is coming back. Best of luck with the project keep us poste and if any of you are planning to buy a KB block just make sure you deal with KB directly. Twin turbo mopars hopefully I can get the R5/P7 together one of these days, I'm building a pump gas street car though.
outlawdemon
tweety are you the one that had the cuda,that was over dennis.that was doinng the smallblock turbo. john
tweety
Yes John that's me, the plan changed a bit though, the blue cuda I had down there is becoming a bit of hybrid ricer/muscle car ( I know I'm waiting for all of the abuse!) and the turbo R5 motor is going in my right hand drive 69 cuda. Let's hope Dennis gets the wagon done soon, I know he's crazy busy with that big old monster. Listen I have that big Mark Williams Promod axle sitting here that was going in the cuda- along with all the Vanishing Point 4 link suspension stuff, I won't be using that or the new Weld rims, any of the racers out there building a car might save a chunk of cash over buying new! Email me John and we can make contact that way, things get a little (??) crazy around here and sometimes I don't log in here for weeks- keep in touch and best of luck with the car, it'll be a riot to drive, tha's for sure! santa4
CudaSRT8
On the Barton issue, I'd heard of him for years and was looking forward to doing business with them. I was originally going to have them build me a 440-6pak for my cuda. I think it was "Craig" that I talked to that was VERY arrogant and non-committal to time frame, pricing, etc. Had talked with other shops too, and just plain decided to go a different route, hence, brand new SRT8 Hemi. I'm real happy...
tweety
Got it John and sent you one back with my phone #, let's see if we can hook-up later when the kids have gone to bed, that MW stuff is exactly what you need! Man this car is going to be SO FAST, finally someone in the Mopar world is going to go kick some butt in the 10.5W class, there's some serious opposition, but hey that only makes you try harder- best of luck and I look forward to speaking to you.
wes
barton is alittle slow getting engines done. took me like 8 weeks to get my 572 B1 back from him the last time i had him work on my engine. you should of called KB and ordered it from him. took me 5 mos. to get to the top of the list. by that time i had my block repaired and had it back together. now its a 580ci B1. call mike at muscle motors, he will fix you up.
