July 18, 2008, 08:17:15 PM
| | |-+  motor plate or schumacher mounts ?
Author Topic: motor plate or schumacher mounts ?  (Read 384 times)
446jeff
« on: December 20, 2006, 12:37:30 AM »
ok guys,i finally found an A body to put my 440 in.i'm making just shy of 600 hp,what would you suggest a motor plate or the Schumacher mounts?this car will see more track than street time.
fasttcars
Re: motor plate or schumacher mounts ?
« Reply #1 on: December 20, 2006, 01:09:33 AM »
mounts are simpler plus the schumacher's are very sturdy......motor plate has more clearence for external oiling system.......
rebel
« Reply #2 on: December 20, 2006, 01:46:29 AM »
the plate is going to vibrate the whole car but if your into track action thats not going to be an issue
fasttcars
« Reply #3 on: December 20, 2006, 02:15:56 AM »
the chicks like it like that...
rebel
« Reply #4 on: December 20, 2006, 05:32:34 AM »
don't they just, i took a young lady for a ride down the 1/4 in my 'cuda, open pipes, solid mount on 1 side, rubber on the other, she got out of the car & instantly blurted out, "thats better than any sex", her new boyfriend wasn't impressed. she loves leaning on the car when the motors running in the pits, chicks... go figure.
446jeff
« Reply #5 on: December 20, 2006, 09:04:35 AM »
 yes they do,the engine is currently in my Roadrunner(solid mounts) & they love when it sets at stoplights.
Blue
« Reply #6 on: December 20, 2006, 12:22:13 PM »
'plate!
lake worth, florida
55robert@bellsouth.net
« Reply #7 on: December 20, 2006, 12:33:44 PM »
plate. you can move the motor around to get needed clearance to everything.
lake worth, florida
« Reply #8 on: December 20, 2006, 12:36:26 PM »
she loves leaning on the car when i motors running in the pits, chicks... go figure.
Quote
  Cool
Chris_Holliday
72 dart 440, 906's, .509 runs 12.30's
« Reply #9 on: December 20, 2006, 01:52:38 PM »
the plate makes things much easier.  lots of room for headers, adding alterkation, starter removal, etc
Ohio
Charles
« Reply #10 on: December 20, 2006, 02:47:27 PM »
I agree, the plate gives more room for everything and really isn't much more work than trying to get mounts to fit...
Doesn't say much for the boyfriend, does it  taunt
-Charles
ucdcrush
« Reply #11 on: December 20, 2006, 07:40:09 PM »
Comp engineering sells either a 1 piece or 2 piece, is either one easier to work with? What other parts are needed (gaskets, spacers?) when using a plate?
rebel
« Reply #12 on: December 20, 2006, 11:10:46 PM »
i'm using comp eng's 2 plate deal, had to make a small notch in the bottom of the plate to squeeze between the rails but that's real easy on an A body, takes meer minutes. the steel brackets can then be migged onto the rails. i think the whole install took less than 30 mins & i'm not a pro. this kit locates the engine squarely in the middle of the engine bay. the only extras reqd to install are 2 more water pump gaskets.
nah it didn't charles but that b/f has since been given the boot. chicks huh?
