Topic: strut question (Read 437 times)
wickedfirefighter
oroville, ca
i just put strut and brake kit on a 67 cougar and liked the handling so much i want to do it to my dart ..who makes the struts kits for mopars..
GT_convert.
Better do a bit of homework and know the difference between a coil spring/strut and a torsion bar type front suspension  !! How can you mention the 'M' word on this site?? Bill has a far superior front suspension available in the AlterKtion!!
Road Racer 40 years of go-karts, motorcycles, & cars...with a hydro-plane every once and awhile to cool things down! No such thing as too much HorsePower!!
B1Valiant
Well there is one "bolt in"(requires a good deal of welding) kit out there. It is made by Magnumforce racing. Dont know anyone who has used one but I have seen one on a car they built. Are you sure it was a strut kit you installed? They require a good deal of fabrication work and welding due to the overall length of the struts themselves.
AAOUTLAW
an A body mopar is to archaic to cost effectivly put struts in....you'd be better off putting an M1 tank of a cast iron old style big block 440 into a car with struts
ya you need to do a lot of mod work to put a strut on a mopar like my coronet.....but it is a 200mph front suspension
acpat
fasttcars that is nice nice
wickedfirefighter
oroville, ca
my goal is to get a lighter ,better handling and steering front end with out going to a magnumforce kit ..i want to eliminate the torsion bars .. i would like to do a wilwood front hub kit , rack and pinion and sway bar front end .. is it possible with a stock K frame?
yep...but the rack will be a bunch of work....
wickedfirefighter
oroville, ca
does anyone have pics of a rack already in A -body
ask w2-408 his dad has a rack in his 68 valiant[lots of work to function properly].....this is a pic of a rack in a b-body but not an easy build..... [attachment deleted by admin]
wickedfirefighter
oroville, ca
instead of doing a rack in my car can i change my steering ratio in my manual box ..
W2-408
Leduc Alberta Canada
Sometime this weekend I'll try to snap some pics of the rack in my dads Valiant. He still has the stock K-frame, but as Fastcars said, it is a lot of work, hopefully he will do one for my Duster next winter. santa1
1973 Duster 360/904, 11.19@ 122.39mph...... for now, and still driven almost daily
Yes, Firm Feel has several ratios available.
'67 Notchback- 12.85 @ 109mph
B1Valiant
Well typically aftermarket strut kits are not very street friendly. They are not set up for street driving at all. If it is a street car then I think the AlterK is the BEST piece out there.
