October 11, 2008, 12:29:34 PM
| | |-+  k-member
Author Topic: k-member  (Read 680 times)
1972 dart
k-member
« on: January 02, 2007, 03:43:02 PM »
hey guys,i need some help to decide what k-member i have in my 72 dart , slant 6 or v8 ?
original it's a / 6 car,i bought the dodge with a 318....
who can help me out?
i have some pic's:
thanks,
alfred
BULLSI3
BULLSI3
Re: k-member
« Reply #1 on: January 02, 2007, 06:24:58 PM »
Looks like a mighty six to me . If it were a small block , the passenger side horn would be much closer to center & about in line with the idler arm .
1972 dart
Re: k-member
« Reply #2 on: January 02, 2007, 06:29:39 PM »
thanks,and wellcome.
i have to be sure,because i have to order a pair off engine mount for the /6 -318 conversion....
alfred
ski
Re: k-member
« Reply #3 on: January 02, 2007, 07:12:02 PM »
Check out this post.
http://www.bigblockdart.com/index.php/topic,12504.0.html
Schumacher's site shows a bunch of different pics.
http://www.engine-swaps.com/
1972 dart
Re: k-member
« Reply #4 on: January 03, 2007, 06:37:47 AM »
thanks guys,it's a slant 6 member thus...
alfred
1972 dart
Re: k-member
« Reply #5 on: January 03, 2007, 06:50:58 AM »
okay,last question.....
i found these,a lot cheaper than the shumachers.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=TRD%2D4695&N=700+4294908110+115&autoview=sku
it says,for 340/360 so will it fit on a 318 engine with some  minor modification?
or are the 340/360/318 mounts the same?
alfred
fasttcars
Re: k-member
« Reply #6 on: January 03, 2007, 07:18:39 AM »
they are all the same if anything sometimes on the 360 you have to grind a slight notch on the driver side...but 318..340...basically the same block...
Bill_Reilly
Administrator
White Haven, PA
Re: k-member
« Reply #7 on: January 03, 2007, 08:19:28 AM »
The 273/318 driver side mount is 3/8" wider - otherwise they're the same. So if you use a 318 mount and put a couple washers on the rear hole, it'll fit fine. But if you put a 360 mount on a 318, you have to grind the ear narrower.
1972 dart
Re: k-member
« Reply #8 on: January 03, 2007, 08:47:35 AM »
thanks guys,thats the info that i need,no problem to fix it.
alfred
