Topic: k-member (Read 671 times)
1972 dart
k-member
« on: January 02, 2007, 03:43:02 PM » |
hey guys,i need some help to decide what k-member i have in my 72 dart , slant 6 or v8 ? original it's a / 6 car,i bought the dodge with a 318.... who can help me out? i have some pic's:     thanks, alfred
BULLSI3
Looks like a mighty six to me . If it were a small block , the passenger side horn would be much closer to center & about in line with the idler arm .
1972 dart
thanks,and wellcome.
i have to be sure,because i have to order a pair off engine mount for the /6 -318 conversion....
alfred
1972 dart
thanks guys,it's a slant 6 member thus...
alfred
1972 dart
they are all the same if anything sometimes on the 360 you have to grind a slight notch on the driver side...but 318..340...basically the same block...
The 273/318 driver side mount is 3/8" wider - otherwise they're the same. So if you use a 318 mount and put a couple washers on the rear hole, it'll fit fine. But if you put a 360 mount on a 318, you have to grind the ear narrower.
1972 dart
thanks guys,thats the info that i need,no problem to fix it.
alfred
