Topic: solo brake bleeding (Read 518 times)
PinkE
A New Journey Begins.....
PinkE
Finally....
ucdcrush
Over on moparts a lot of people were saying recently that they just 'gravity' bleed the brakes, keep the master cylinder full, open up the bleeders and let mother nature do the work.
Crazy68Dart
This way works as good as any, but takes a little time. I gravity bleed now, where as I used to have a second person to work the pedal. You can damage the master cylinder working the pedal to bleed the brakes. I also have a pressurized bleeder, which works great, but I only have it setup for one type of cylinder. Honestly, gravity is easy, hassle free, and I find it to be less of a mess.
Xwaynestaticx03
itll get past the valves and reg. fine, it works well. in my experience though, gravity bleeding will get you 95% there. id just do a pump or so in each bleeder after and youll be good to go...
Brad4406
It works, I've seen bike shops do it for years. They just take a small diameter piece of clear hose, attach it to the oil pump can and the other end to the bleeder, open the bleeder and start pumping. You'll start seeing the bubbles in the resevoir, or master cylinder on a car, and then just fluid shortly after that. I'm sure it can't be much different for cars. Don't tell my wife though, I still get her to help me because I'm too cheap to even spend $4.
Brad4406
I've never seen it done with any lines disconnected. I can't get the shortcut at the top to open for me so I don't know what that tool looks like, but the oil can thing works as long as it's a closed system other than the open bleeder with the oil pump can attached to it.
71 demon child
I gravity bleed.never had a problem.
taking donations
Capt Jack
I never bleed. brakes are for sissys.  (kidding. I need some of those valves)
73swinger
The way I've done it in the past is to connect a small plastic tube onto the bleeder screws and run it (as short as possible) into a jar filled half way with brake fluid. You have to make sure the hose stays below the fluid in the jar, then you crack open one bleeder screw at a time (starting with the furthest) and pump the brake s a few times. this will force the bubbles out rather quickly into the jar and when you let off the pedal, the hose sucks fluid back up. I usually put a decent amount through each screw, making sure not to let the master go dry. when the bubbles stop, tighten the bleeder and move on to the next wheel.
I've never had a problem doing this by myself, and it's worked every time
pandamarie
I hook up a clear plastic tube on my bleeders and make a loop that goes up about 8 inches held with some tape, crack the bleeder open and push the pedal down slowly 3 or 4 times and hold it for about 5 seconds each time before letting up, the air will go to the top of the tube and the fluid will run back into the system get out and tighten up the bleeder and move to the next wheel, has never failed me yet.
74swinger
 .....doing it this way for years on jap craps to motor homes. Never a problem just make sure all the fluid in the system is clean. Mixing dirty and clean fluid makes clean really dirty  . Someone there to watch for the lack of bubbles really helps also......."oh sweetie, can you get on all fours and put your head down while I pump...."
268darts
A mechanic friend of mine uses a bug sprayer half full of brake fluid. He has a MC cap with a fitting connected to the sprayer. Pump it up and you have a pressurized bleeding system.
urchinhead
So, Pandamarie and 74Swinger - do you take the line and wire/tie it up above the wheel housing? I was thinking of trying this by tying a long clear tube up to a garage stool. People never want to help me bleed my brakes, and I can't say I blame them.
73swinger
keep that tube as short as possible, just long enough to reach the floor from the bleeder screws. remember you are trying to push the bubbles out of the lines. when you let off the pedal fluid will be drawn into your lines through the plastic tube. if the tube is too long, the bubbles will just move down the tube, then back up it. pretty neat looking but probably won't help your brakes any
74swinger
[]{}The tube short and straight down (more or less) into the bottle. Don't kink the tube. No need to wire anything up. Do only one corner at a time, and test it when you are done. Worst case, you waste a pint of brake fluid doing it over again. A tool box under the car, set the bottle/can on top of it to make the tube really short, and pump slow and steady. No bubbles, no troubles.
WildCat
Bought a mini vac at Auto Zone for about $25. Works greta but don't use on anti lock brakes..........doubt any of us have them on our old cars but for those that work on the new stuff too a good reminder
Fill master cylinder with fluid, starting at bleeder farthest from master cylinder, attach hose from mini vac to bleeder, open bleeder, pump lever on mini vac.
I used it to change the brake Fluid on my Prowler and to bleed the Dart brakes and it worked great. Well worth the money and not having to ask anyone to pump the pedal, especially when changing the fluid out completely.
Just keep and eye on the master cylinder so it does not run out of fluid.
67 Dart Convertible "340" 4 speed, Custom Interior "Do It Again" 81 Imperial 14,000 miles, UNRESTORED 99 Plymouth Prowler "WildCat" custom paint, chrome wheels, grill & doorhandles
