August 28, 2008, 01:52:54 PM
| | |-+  need help wiring up a battery cut off switch
Author Topic: need help wiring up a battery cut off switch  (Read 334 times)
440darting
« on: January 03, 2007, 11:14:15 AM »
I have a GM 1 wire alternator on my 400 big block motor and a battery cut off switch mounted at the trunk with my battery in trunk. How do I wire this switch up so that it kills the motor when turned off, I need this done to run at the track, could someone send me a wiring diagram on how to do this via fax , my fax number is 301-314-9663, also you could send a attachment via email, that adrees is  roadrunner69383@yahoo.com
signet
Re: need help wiring up a battery cut off switch
« Reply #1 on: January 03, 2007, 01:43:16 PM »
you need to use a cut-off switch with 2 circuits(2 pole single throw type),one does the battery and the second one is the power to/from the alternator.
you will need to beef this wire up now that it has become 4 times as long going to the rear of the car.
you can use a relay to keep this wire short but vibration can cause it to invoke Murphy's law,and there is the additional parts ect.
Allentown, PA
« Reply #2 on: January 04, 2007, 10:02:08 PM »
Easy one ... call summit racing and order a "tay-1033" come with wiring instructions.   I'll send you a PDF copy of them in an E-mail.
rharveysr
« Reply #3 on: August 15, 2008, 10:37:54 AM »
Can you send me the same file please....
thedieselbunch@yahoo.com
Thank you
Rick
Prodart
« Reply #4 on: August 15, 2008, 09:02:59 PM »
Run the ignition power to the battery side of cut off switch Grin
west
« Reply #5 on: August 15, 2008, 09:27:30 PM »
put the ALT wire on the + batt. side of the switch and the ign.(starter) wire on the other side of the switch
                moparts can kiss my ass  moon
