October 07, 2008, 06:51:15 PM
| | |-+  whats it usually cost to mini-tub car
Author Topic: whats it usually cost to mini-tub car  (Read 1254 times)
Re: whats it usually cost to mini-tub car
« Reply #30 on: January 05, 2007, 11:29:52 PM »
anyone else have some costs to tub?can you do this without messing up the paint on the outer skin?if so how is it bonded to the quarter?
automan63
« Reply #31 on: January 06, 2007, 12:13:51 AM »
West, check into the tech pages  http://www.bigblockdart.com/techpages/wells.shtml  I think you'll see that you dont really have to get into the outer qtr, but you will do some welding on the floor and inner wheelhouse.
6pkScamp
Small block Scamp Brooksville,Fla.
« Reply #32 on: January 06, 2007, 08:45:03 AM »
I'm sure it's been discussed here somewhere, but what kind of saw or cutter is the right tool(s) for a mini-tub project.  I suspect maybe a plasma cutter is the right answer, but I don't have one.  Can you do it all (well) with a regular Sawzall?  Did I see someone mention a mini-sawzall?  Will an air driven cut-off tool also help?  What's the hot set-up?
Thanks,
John
I used a 4" angle grinder with 6",.045 cutoff wheels and a sawzall. Bought a mini body saw from Harbor Freight, waste of money. The angle grinder with the wheel is your friend. After a buddy turned me on to a couple of wheels I use them to cut anything.
68droptop
« Reply #33 on: January 06, 2007, 04:44:33 PM »
I just went to the hardware store and all I could buy were 7" metal cut-off wheels.  I guess those will work too?  It sounds like this would cut some metal, but it also scares me some because I remember that one time my dad was using a smaller cut-off wheel when it exploded and ripped a big slice in the ceiling.  In fact, I just checked my stuff and the grinder is supposed to turn 12,000 rpm and the 7" wheels are rated for 8,500 rpm max.  Do I need to find some different (6") wheels or buy a different grinder?
Thanks,
John
« Reply #34 on: January 06, 2007, 04:52:20 PM »
the larger wheels will slow the rpms,you should be fine.i always put on my goggles before even hooking up the air.
68droptop
« Reply #35 on: January 06, 2007, 05:38:05 PM »
I also bought a full face shield, but I was thinking that if the damn thing came apart it could cut my throat.  You should see the damage to the drywall ceiling in my dad's garage...
I think you're right about the RPM of the grinder with the bigger wheel.  Plus, it's a cheap grinder and I suspect that 12K rated rpm is an exagerted no wheel free spin speed.
Thanks,
John
johndart
« Reply #36 on: January 06, 2007, 11:44:41 PM »
Hey 6pk Scamp
that looks so right. could you email me a picture
thanks ,
Johndart
« Reply #37 on: January 07, 2007, 12:06:49 AM »
we kind of replaced (by default) our sawzal by our new dewalt 4 inch battery powered grind, i love that thing
6pkScamp
« Reply #38 on: January 07, 2007, 02:58:45 PM »
Thanks,
John
A full face sheild is also important, I also wear my welding gloves, those 6" wheels are darn close to my digits. The wheels I use are 14200 rpm and my Dewalt angle grinder turns 10000.
« Reply #39 on: January 07, 2007, 03:01:21 PM »
Thanks,
John
and when those things break and go flying....i can actually say ouch...
68droptop
« Reply #40 on: January 07, 2007, 03:43:20 PM »
6pkScamp,
Where did you find those 6" 14K rpm cut-off wheels?
Thanks,
John
6pkScamp
« Reply #41 on: January 07, 2007, 04:13:02 PM »
6pkScamp,
Thanks,
John
    My favorite wheel is made by Spartan 1-800-321-4010 not sure if thats a good phone#, also Metabo and Sait are other brands. I pick them up at the swap meet.
Pages: 1 [2]  All Go Up Print
