October 11, 2008, 12:24:14 PM
| | |-+  Engine Paint
Author Topic: Engine Paint  (Read 492 times)
urchinhead
San Francisco, CA
Engine Paint
« on: January 12, 2007, 12:46:26 AM »
I've just finished tearing my engine down, and I'm going to repaint the block and heads. What engine paints are people using? Anything good out of a can? And what about prep?
68 HEMI GTS
Re: Engine Paint
« Reply #1 on: January 12, 2007, 12:27:06 PM »
my last engine i had the paint shop mix up a quart of hemi orange enamel and put in spray cans, but in the past ive just shot them with acrilic enamal out of the gun on bare cast iron and the've held up good.
Birdius Rapidus
Re: Engine Paint
« Reply #2 on: January 12, 2007, 12:49:26 PM »
One prep method I like doing is hitting it with a propane torch prior to painting. You can watch the pores of the cast iron "dry out" as you work the flame removing any residual cleaners or moisture.
Tom
Ciscodog
Re: Engine Paint
« Reply #3 on: January 12, 2007, 01:11:05 PM »
Good call Tom!  I've seen that happen before but it never occurred to me to use it as a paint prep.
Long Island, NY
Re: Engine Paint
« Reply #4 on: January 12, 2007, 01:21:14 PM »
Tom's idea works great. I always used to do that when I painted headers with VHT. Nobody could ever figure out why my headers stayed painted.
I've mentioned in a similar thread that Plastikote is great engine paint from a spray can. The Hemi Orange covers good and cleans up nice.
mopardude318
Re: Engine Paint
« Reply #5 on: January 12, 2007, 01:42:03 PM »
i used the por 15 engine paint kit..came out real good
1970 Dodge Dart, 408 sb, eddy heads, 4 spd, alterktion, 8 3/4
Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax. - David Charles Gedraitis
urchinhead
San Francisco, CA
Re: Engine Paint
« Reply #6 on: January 12, 2007, 02:02:11 PM »
I was actually thinking about using Por 15 for painting my engine compartment. It seems that there are three parts to the basic kit, and then I can topcoat it ( degreaser, primer and paint, + whatever topcoat, right? ). I'm assuming that the engine paints are a little different. Oh, and the torch heating sounds like a good idea, especially for the headers. Thanks guys, any further input would be geat as well.
eldubb440
Go Phillies!
eldubb440
Re: Engine Paint
« Reply #7 on: January 12, 2007, 02:03:40 PM »
sprayed mine with brake clean.......cover coat of epoxy primer.......2 coats u-tech 3.8
jamesdart
Re: Engine Paint
« Reply #8 on: January 13, 2007, 08:54:19 AM »
eldubb, do you have  a paint code for that turquiose?
eldubb440
Go Phillies!
eldubb440
Re: Engine Paint
« Reply #9 on: January 13, 2007, 12:04:15 PM »
the flash and poor lighting makes the picture look light blue, but i matched the turquoise pretty close. i had the paint store somewhat match  it to an original part, but they made it too blue. they gave me some yellow tint i added till i was happy.
wild383
'74 Dart Sport. Almost finished. Sawyer, MI
Wild383@live.com
Re: Engine Paint
« Reply #10 on: January 13, 2007, 05:27:03 PM »
I've used the POR 15 engine paint on a couple of engines and it seems to work great. Good coverage and stays in good shape a long time.
383 bored .030, Stage IV iron heads ported with MP templates. 11. to 1 comp. MP .528 mech. cam. Holley TBI. TF-727 w/B&M 10" 3000 stall conv. 8. 3/4" w/4.10 suregrip, moser axles.
72Dart_400
Rome, PA
RyanRM340
Re: Engine Paint
« Reply #11 on: January 16, 2007, 12:01:51 AM »
Plastikote is by far the best spray bomb engine paint out there!
eldubb440
Go Phillies!
eldubb440
Re: Engine Paint
« Reply #12 on: January 29, 2007, 11:29:50 PM »
i had a small crack on a bolthole to heat and weld.....the immediate area obviously burned away, but the close surrounding paint held up awesome. ill be able to spot right back into it.
abodyjoe
South Jersey...
abodyjoe
Re: Engine Paint
« Reply #13 on: January 30, 2007, 09:12:11 AM »
i have to agree with eldubb..  the epoxy primer and u-tech 3.8 is great stuff.  i used brake-kleen to clean up my motor and djv sprayed it for me....
  i'll tell you that paint really holds up..  i have spilled all kinds of gas on it doing jet changes and it hasn't touched it.  oil hasn't done anything to it, when i clean it up it looks as good as the day it was sprayed...
from this mess..
to this..
to primer
to paint..
aaahh. much better..
eldubb440
Go Phillies!
eldubb440
Re: Engine Paint
« Reply #14 on: January 31, 2007, 11:23:37 PM »
the epoxy really bites into the cast, i have awesome adhesion. check out how the paint edge feathered with no problems at all. no chipping or peeling....... i masked along the a few edges and casting seams, hit the existing paint with a scotch-brite,  spotted it in and im ready to rock and roll!  drinks
AdamR
Re: Engine Paint
« Reply #15 on: February 01, 2007, 02:09:09 PM »
I used the POR15 kit looks good but now I wish I went with blue instead of orange.
www.forabodiesonly.com
Forums and classifieds
