July 24, 2008, 01:43:52 AM
| | |-+  front coilovers
Author Topic: front coilovers  (Read 1267 times)
griff70440
front coilovers
« on: January 20, 2007, 05:09:30 PM »
is it possible to use coilovers with a stock front end if you added bracing the shock tower bracket?would you be able to remove the torsion bars?
thanks mike
71 Pro Street
CENTRAL JERSEY
Re: front coilovers
« Reply #1 on: January 20, 2007, 06:43:38 PM »
There really is no way to make some sort of bracket to support the aft part of the control arm to accept coil overs without being safe and functional. The only correct way to use coil-overs is with a tubular front suspension.
71
abodyjoe
South Jersey...
abodyjoe
Re: front coilovers
« Reply #2 on: January 20, 2007, 07:00:25 PM »
there are a few racers that did it at moparts.... may want to check with them..
B1Valiant
Re: front coilovers
« Reply #3 on: January 21, 2007, 12:35:32 AM »
Well I have done it one five cars so far with no issues. The current car has the same set up, MF tubular control arms and Coil overs. The shock tower is tied into the front cage struts. Never had any issues at all with this set up.
lake worth, florida
55robert@bellsouth.net
Re: front coilovers
« Reply #4 on: January 21, 2007, 12:38:33 PM »
 i did it too. i have the front inner fenders in place also.
griff70440
Re: front coilovers
« Reply #5 on: January 21, 2007, 04:40:46 PM »
do you guy have any pictures of how you did it?I`d like to keep the inner fenders  if possible.
thanks mike
orange_dart_440@yahoo.com
lake worth, florida
Re: front coilovers
« Reply #6 on: January 21, 2007, 05:47:03 PM »
buy the coil-overs and the stud adaptor from bill and take the torsion bars out. nothing to it.
Blvedere
Re: front coilovers
« Reply #7 on: January 21, 2007, 06:38:53 PM »
What is the benefit of just switching over to coil-overs. Is there a real performance advantage, or is it just something to do, so you can say I have coil-overs? Not trying to be a wise guy but really want to know.
griff70440
Re: front coilovers
« Reply #8 on: January 21, 2007, 06:49:59 PM »
I`d like to put coilovers  and remove the torsion bars. that would give me more room.
fasttcars
Re: front coilovers
« Reply #9 on: January 21, 2007, 07:42:03 PM »
i got coilovers in the front of my car also.....no big deal....but i originally installed the magnum force converion..and pulled my torsion bars but i didn't like how high the car sat[just me]......so i modifies the lower control arm to position the lower coilover mouting bolt lower...and i modifired the top mounting position as well...so now at this point i had my stance how i wanted it....but the car was kinda floaty in the front...without the torsion bars....and with e the car being low this was no good because it would tend to bottom out....so i put the torsion bars back in now the front is stiff as ever and perfect for the car...but it kinda negat's  the benefit's of being able to leave the torsion bars out.......
440dstr
Re: front coilovers
« Reply #10 on: January 21, 2007, 08:27:16 PM »
PICS PLEASE bbd sign bbd sign Shocked
fasttcars
Re: front coilovers
« Reply #11 on: January 21, 2007, 08:30:09 PM »
cars parked for winter...but i might be able to plow through the snow to get to the car and grab a shoot
lake worth, florida
Re: front coilovers
« Reply #12 on: January 21, 2007, 08:35:01 PM »
the advantage is less weight but more importantly more room for headers.
B1Valiant
Re: front coilovers
« Reply #13 on: January 22, 2007, 01:15:30 AM »
Well I did it for header clearance. Trying to stuff 2 1/4" headers in a 67 Valiant engine bay is a bit of challenge. It really is a no brainer deal. Buy or a set of adapters or attach them to your front strut bars. Drop in the coil over and your set. I also drill and tap the stub shaft from the lower control arm for a 3/8" hole and fit it with a washer to hold the the stub shaft in place. Not really needed but makes me feel better. Pics I have lots of pics..Here are a couple..
Blvedere
Re: front coilovers
« Reply #14 on: January 22, 2007, 11:59:33 AM »
Hey B1, Did you change the lower control arm. Do you have any pics of the lower control arm after you removed the T bars ?
B1Valiant
Re: front coilovers
« Reply #15 on: January 22, 2007, 12:10:19 PM »
I use the stock lower control arm/ I drilled and tapped the rear of the stub for a 3/8" bolt. I install the bolt with a large washer that covers the whole, just to make sure it wont go anywhere. I also weld the old T bar adjuster in place so it wont rattle around. Dont think I have a picture though and at this point you would nto be able to see it..
Blvedere
Re: front coilovers
« Reply #16 on: January 22, 2007, 04:04:26 PM »
Thanks for the reply.
Bill_Reilly
Administrator
White Haven, PA
Re: front coilovers
« Reply #17 on: January 22, 2007, 04:13:49 PM »
I think DusterDave has a group of pics on his website. Can't remember his web address...
abodyjoe
South Jersey...
abodyjoe
Re: front coilovers
« Reply #18 on: January 22, 2007, 04:54:47 PM »
here ya go...    http://www.hemiduster.com/coilover.htm
griff70440
Re: front coilovers
« Reply #19 on: January 22, 2007, 08:20:54 PM »
thanks guys for all the replies.B1 your car looks bad ass.I like the stance.is the car backhalfed?
mike
440dstr
Re: front coilovers
« Reply #20 on: January 22, 2007, 08:22:57 PM »
thanks for pics more would be great.question;how much weight do you save? duster
440dstr
Re: front coilovers
« Reply #21 on: January 22, 2007, 08:26:41 PM »
B1 are those custom headers?  thank you thank you duster
440dstr
Re: front coilovers
« Reply #22 on: January 23, 2007, 01:20:47 AM »
does bill sell this kit? thank you bbd sign
B1Valiant
Re: front coilovers
« Reply #23 on: January 23, 2007, 01:35:27 AM »
Ok here goes...First off thanks for the kind words. The car is NOT back halfed. It is simply a minitubbed car with a TRUE 10.5" tire. Yes the headers are custom Step pieces that are all inside the framerail.
Bill_Reilly
Administrator
White Haven, PA
Re: front coilovers
« Reply #24 on: January 23, 2007, 09:59:41 AM »
I don't sell a "kit" to do it - The other company makes the aluminum upper brackets and adds them to normal coil-overs. I don't even bother with it - It's just a pair of coil-overs and a set of tube a-arms. The stock stud-type mount works fine and allows a longer travel shock, but good luck convincing anyone of it.  Just grab a pair of adjustable upper arms from somewhere(mine or elsewhere, they're all similar aside from price), and choose a pair of coil-overs with a stud-top mount, in the 11-17" range. QA1 5855's are 11.5 - 17", AFCO 1850's are 11.5-16.5", Varishock 515's are 11-16",ect,ect.  11.5"-16" will allow more travel than the stock bumpstops, so anything in that length range works fine.
Over time, the stud-top bushings can get beat up, but they're like $10 at any napa store and take 5 minutes to change. I believe Shingler uses the bushing tops - he can give you an idea how long they last.
I agree putting a screw in the back is a good idea...it's not a part you want falling off...
440dstr
Re: front coilovers
« Reply #25 on: January 24, 2007, 12:12:38 PM »
 i love this site. seems like i learn something new everyday. and the real kicker is what i learn is either cheaper, better, or at least interesting bbd sign
Ciscodog
Life is hard. It's even harder if you're stupid!
Re: front coilovers
« Reply #26 on: January 24, 2007, 09:11:24 PM »
Rather than drilling/tapping the stud, I welded a nut on the end and used a bolt/washer setup.  Serves the same purpose.
HemiDenny
Re: front coilovers
« Reply #27 on: January 26, 2007, 05:48:53 PM »
I've used this setup with chromoly tubing sleeves welded through the front rails. no problems.
TTi headers (B-E body Hemi or RB) fit great......just get rid of the steering box and use a rack.
65DartGT
Montville,CT
Re: front coilovers
« Reply #28 on: January 26, 2007, 06:17:27 PM »
This can't be done without renforcing the upper shock mount right? The stock shock mount isn't strong enough to hold the cars weight is it?
Blvedere
Re: front coilovers
« Reply #29 on: January 26, 2007, 06:55:08 PM »
     Have you installed a rack and retained the K member. If so could you post some pics and info of how you did it?
Pages: [1] 2  All Go Up Print
