October 15, 2008, 11:13:20 PM
| |-+  Early A-bodies
| | |-+  I got my Maverick 8" in the Dart last night.
Author Topic: I got my Maverick 8" in the Dart last night.  (Read 1959 times)
3404bbl
« on: February 01, 2007, 05:01:38 PM »
 Smiley It fit like it was made for the '63 Dart. I put 15" cop car wheels on. They fill the wheel well out really nicely. PLenty of clearance.
I'd rather had an 8 3/4", or probably even an 8 1/4", but I couldn't turn this one down for the money.........free!
The 8" is a pretty stout rear, so if you want something that will bolt in without any trouble, the Maverick rear is almost the same
dimensions.  I was even able to move my brake lines off the 7 1/4", with minimal, and I mean "very minimal" bending to get them
to match up.
Bottom line, it's a great swap!
urchinhead
San Francisco, CA
Re: I got my Maverick 8" in the Dart last night.
« Reply #1 on: February 01, 2007, 05:24:47 PM »
I've got a '63 1/2 Falcon too, and the stock 8" in it's pretty stout, though I'll probably go 9" or 8.8" in the distant future. The 8" is a pretty good starting point - a lot better than a 7 1/4"
fstfish66
« Reply #2 on: February 09, 2007, 01:39:54 AM »
dumb question,,,is the  maverick doner car a leaf spring or coil car ?? if leaf did you have to move the perches?? to fit the dart....
1966 barracuda blown 340 4 speed tubbed 33x22
1940 dodge street rod hemi with A/C
2002 cummins ram dailey driver
3404bbl
Maverick 8" is a direct bolt in.
« Reply #3 on: February 09, 2007, 09:34:07 AM »
There wasn't over a 1/4" difference in the spring perches. My brake lines from the 7 1/4" were still good, so I moved them over to the 8" also, with very little effort. My digital camera is semi-functional. If I get it working, I can take some pics and post.
fstfish66
« Reply #4 on: February 18, 2007, 02:40:44 PM »
 i know street rodders use this swap,,an 8 inch out of a lincoln versalies,,,(not sure what that looks like) because they have rear disc brakes,,,,,,very kool even know its not a 8 3/4,,but hexk like you said it was free,,, and it fits,,,with the rising costs  of  8 3/4 these days,,,a free swab is a good deal,,,
BBLM23
Poughkeepsie, NY
« Reply #5 on: February 18, 2007, 02:48:27 PM »
I bought a Dart with an 8 inch swapped into it. I guess he used the Mopar u-joint. It wasn't quite right, there was a little play in it and the straps didn't cover the cross. I blew u-joints like crazy. I swapped to 8 3/4...
Walter
1981 Dodge Aries 451 B1/BS
Best 1/4 9.871 at 136.01mph
1969 Dart Swinger 431 B1/BS
Best 1/4 10.649 at 126.45mph
Racing Pro in street trim.
1981 Plymouth Reliant 400
fstfish66
« Reply #6 on: February 18, 2007, 03:01:24 PM »
 it would of been easier and cheaper to go get the correct u-joint,,,
BBLM23
Poughkeepsie, NY
« Reply #7 on: February 18, 2007, 03:05:58 PM »
It was the correct u-joint, for a Mopar.
Walter
fstfish66
« Reply #8 on: February 23, 2007, 03:10:12 AM »
i didnt meen to sound  like you may have taken it,,sorrry,,all i ment was is that there are what they call bast**d u joints that are made  that have 2 different sizes on the same joint,,made for  custom applacations like  what you had,,,
so if ya got a 8 or 9 inch laying around,,,use it,,,a u joint is cheaper then a different rear,,unless  its freeeee
didnt meen sound sarcastic,,,,just trying to help,,,
moparbubba
« Reply #9 on: February 28, 2007, 03:58:13 PM »
Do the Maverick axles have 5 lugs?Huh Are the wheels 5x4.5?Huh
7173Duster
« Reply #10 on: February 28, 2007, 04:07:21 PM »
A small Moper joint and a small ford joint are the same except for the clip style on the cap.  The mopar has a machined groove for the clip on the inside of the yoke and a ford has a smooth cap for the clip to fit outside of the joint in the driveshaft or transmission yoke.  If I were to bet the real reason for going through U-joints is that a Ford offset and a Chrysler offset are different.  More than likely you will see that the yoke sits approx 1-1/8" to far to the drivers side as compared to your stock rear.  Just something I ran into in the past.
urchinhead
San Francisco, CA
« Reply #11 on: February 28, 2007, 08:21:07 PM »
Yes.
7173Duster
« Reply #12 on: March 01, 2007, 11:38:07 AM »
I have seen the maverick rears with both 5 and 4 lug.  I think it depended on the options of the car.
urchinhead
San Francisco, CA
« Reply #13 on: March 01, 2007, 02:12:26 PM »
It is possible, but I've only seen 5 lug Mavericks/later Comets...
The 8" axles were either 4 or 5 lug in the early Mustangs and Falcons/early Comets and most that you see are converted to 5 lug if they didn't leave the factory that way. If you find any 8" at a yard, chances are they're 5 lug, but like small bolt pattern Mopar axles, a swap is easy and fairly cheap ( and Ford parts are far cheaper than Mopar parts ).
here's a reference, they list Maverick axles as being exclusively 5 on 4.5" :
http://www.mr2.com/TEXT/WheelBoltPatterns.txt
joesnow
s.e.pa.
« Reply #14 on: March 01, 2007, 08:56:13 PM »
1969 1/2 , 1970 Maverick .1964 1/2-1965 Mustang with a 6 cyl. had the 4 lug wheels.Not a 8"! 5 Lug on 4 1/2' was 1971 & later. 8" and 9" 29 spline use the same axles. Look in a V-8 mustang 1965-1966,1976-1969 cougar,Maverick, mustangII,Pinto. Grin
Poison_Dart
« Reply #15 on: March 05, 2007, 09:22:01 AM »
this doesn't supprize me any,  I have also found that the '79 Granda's rear can be used as a swap in the later model '68-75 Darts , some of these Granada's
have the 9" rears the ones with the 302 engines,   although I'm not sure if it will fit the erlier year Darts?
I just installed one over in a '66 stang and realized that this rear would easily work over in either my '71or '68 darts
as well .
3404bbl
I passed a house today that had two old Mavericks sitting in the yard.
« Reply #16 on: March 06, 2007, 07:33:45 PM »
One was a 4 door, the other a 2 door. They looked rough, so I thought I might go back and see what's under them. I'm looking at a '39 Plymouth that it'd probably fit under pretty nicely too.
I think the Maverick I got my 8" out of was a '75. It does have 4.5" 5 lug pattern.
urchinhead
San Francisco, CA
« Reply #17 on: March 06, 2007, 08:14:04 PM »
I'm not quite sure what you mean to communicate with "Not a 8"!" My 63 1/2 Falcon Futura came factory original with an 8" rear with the five lug ( 5 on 4.5" bolt circle ) pattern - my car is a factory V8, as well. Other than that, yes, the 65 and up Mustangs, Cougars and other vehicles that came with a V8 will all have either an 8" or 9" rear with five lugs. Obviously, you can see how many lugs they have when you look at them, and there is only one bolt circle, unlike Mopars.
joesnow
s.e.pa.
« Reply #18 on: March 16, 2007, 09:11:52 PM »
If I remember right, it had something like chryslers 7 1/4" in it. early 1970 200cu staight six
4spdfury
« Reply #19 on: March 21, 2007, 08:38:41 PM »
so all that required is a conversion joint for the drive line. what about emergency brake cables.
3404bbl
« Reply #20 on: March 23, 2007, 06:59:13 PM »
I used the e-brake cables from the 7 1/4". They're very similar.
kuztomz
damn cats
« Reply #21 on: April 20, 2007, 09:03:04 AM »
Anybody happen to know the brand and part number for the correct U joint to hook these up?
4spdfury
« Reply #22 on: April 20, 2007, 08:32:26 PM »
i used 2 spicer ujoints to make one get one for a 8 inch and one for the mopar drive shaft. use the ujoint cross for the mopar drive line and then use the 8 inch caps for the rear end. i will get the numbers for you in a little while.
kuztomz
damn cats
« Reply #23 on: April 20, 2007, 08:40:13 PM »
Very cool, thank you
4spdfury
« Reply #24 on: April 22, 2007, 07:42:15 PM »
ok the part numbers for the 2 ujoints are 5-1204x  and 5-353x the last one (i think) is for the driveline. you need both these ujoints to make the conversion work. the ubolt for the yolk are 2-94-58x. good luck
kuztomz
damn cats
« Reply #25 on: April 23, 2007, 10:39:36 AM »
Thanks, that helps allot Smiley
pishta
« Reply #26 on: May 30, 2007, 11:26:04 PM »
Wow, I may ditch my 8 3/4 3.91 posi A rear for a Ford 9 and pocket the $700 Ill have left over...Ill even get 5 on 4.5 to boot!
fstfish66
« Reply #27 on: May 31, 2007, 01:12:30 AM »
i recently read an article,,where some one changed to a 9 inch,,and lost X amount of time in the quarter mile,,with the same gearing as the rear end that was taken out,,,i dont remember the time factor lost,,but in that article,,they mentioned,, that there is a bearing,im guessing the front pinion on a 9 inch,, that robbs about 30 horse power,,to turn,,
pishta
« Reply #28 on: June 01, 2007, 11:10:54 PM »
30 HP would create 70,638 BTUs/hr. or 2.6 gallons of water heating at a rate of 1 degree a second.That is boiling a spaghetti coldrun in 2.25 minutes, that is some heat!  That is a lot of heat to go nowhere...but I get your point. That is an innefficient rear. You sure that is a bearing behind that ford pinion or just a flat washer!!
