August 28, 2008, 11:47:29 PM
| | |-+  rearends?!?
Author Topic: rearends?!?  (Read 570 times)
davemac
Work in Progress
rearends?!?
« on: January 26, 2006, 05:24:11 PM »
I have a 74 Dart Swinger - 318 with a 3 speed manual and a 8 1/4
rear end.  Sure it needs floors, trunk and door skins, interior and paint,
but it was delivered for $150.
The Dart will receive a 360 from an 88 Dodge 250 van. Also deliverd for $250.. running!
It will be/is being massaged to 400HP+.  The doner van has a T727 and a 9 1/4 rearend with those funky heavy duty truck
axles.  Can we determine the ratio on the stock 8 1/4 in the Dart or the van?
So,.. I am weak on axles and gear ratio. Even after much time on the
internet, I still need help.  Can I use the 8.25 rearend and change the
gearing?  Can the 9.25 be used?  What about the differences in sizes in
width and other specs?  Cut it down or use the 8 1/.  What other rearends can be put into the Dart?
I will not be racing the Dart - I am planning on a streetable daily driver
I am a interested in good torque and an occasional "smoke break". Pictures
will be sent!!  However, I am not be interested in being passed by old
ladies on mopeds and bicycles. So I know that a change may be in order but
how with the resources a hand?
After seeing the movie of the Dart with it's new T727 posted here I think I will be using the trans from the van?
It ain't much but it was delivered $150
Who's your daddy now?
Sacramento CA.
Re: rearends?!?
« Reply #1 on: January 26, 2006, 05:49:23 PM »
The van should have a long tail shaft 727 in it that is a bolt in with the 360. As for rear ends the 8 1/4 can be build to hold up to the 360. The 9 1/4 can be made to fit and is stronger then the 8 1/4. If you are planning on running larger tires in the back and need to cut the 8 1/4 down I would just get a 8 3/4 and spend the money on that.
Re: rearends?!?
« Reply #2 on: January 26, 2006, 06:10:59 PM »
davemac
Work in Progress
Re: rearends?!?
« Reply #3 on: January 26, 2006, 06:37:27 PM »
I will be using the 727 from the truck.  I assume I will have to cut the drive shaft down?  What gear ratios do you like for the 8 1/4.
All my previous builds have been 4x4 so this will be a little new to me.
Evan
Fayetteville, Arkansas
bigjohncat
Re: rearends?!?
« Reply #4 on: January 26, 2006, 07:00:45 PM »
If you have to cut an axle down, definitely get an 8 3/4 like dustpan said. i have a 360/727 in my duster with a little over 400hp and i have an 8 1/4. I found a new posi unit for $185 from reider racing. I have 3.91:1's and i like them a lot
