May 22, 2008, 04:05:52 PM
| | |-+  Bulb replacement
Author Topic: Bulb replacement  (Read 1004 times)
DART VADER
Bulb replacement
« on: December 26, 2005, 12:48:37 PM »
I've been restoring the instrument cluster and everything in the dashboard of my 69 Satellite. I just found out that the 158 bulbs behind the gauge cluster have 194 replacements. I was trying to find the 158s and couldn't find them anywhere. I discovered the replacements are now 194s. These are the bulbs that fit in the little black knobs that you twist out from behind the gauge cluster.
I know it's a small detail but I figured I would post it anyway. I was banging my head against the wall and not too many shops around here know old Mopars.
bbd sign tried and true
fourspeed
Wisconsin
Re: Bulb replacement
« Reply #1 on: December 26, 2005, 05:43:19 PM »
Doncha hate when they do that - change numbers for no good reason...  Roll Eyes
« Reply #2 on: December 27, 2005, 02:26:42 AM »
Often when looking at a light bulb book, there are lights that are nearly identical and there seems to be no good reason for different numbers.
Dartsport
« Reply #3 on: December 28, 2005, 09:03:11 AM »
#158 bulbs are available thru SYLVANIA. I have them here at my business, I also have #194 bulbs. # 158 bulbs are about .030" to .050" shorter than #194. Either will work.. cat fight
DART VADER
« Reply #4 on: December 29, 2005, 07:11:29 PM »
Really? I couldn't find them.
sr71mopar
Santa Rosa, CA.
« Reply #5 on: December 29, 2005, 10:17:03 PM »
168's and 193's will also work, just make sure you dont use 400's.
rumblefish
« Reply #6 on: January 06, 2006, 01:39:25 AM »
BE CAREFUL they don't make similar bulbs with different part #'s for kicks. Sylvania often makes a simialr bulb in a different wattage or resistance range, problem here is HEAT this can and has caused fires.
rpmrich
i dont burn rubber, i make tires scream
« Reply #7 on: January 07, 2006, 10:44:43 AM »
i just got the sockets for the cluster lights for my 68 dart and the book said the 194's were the replacement bulbs too.
Ft. Worth TX.
« Reply #8 on: January 07, 2006, 12:32:09 PM »
Befor I took my car apart I converted to LED's. Pain but worth it.
Cary Snyder
5.7L Hemi Cuda
