November 20, 2008, 10:45:11 PM
| | |-+  keep'n it legal
Author Topic: keep'n it legal  (Read 474 times)
kowski71400
keep'n it legal
« on: February 08, 2007, 10:57:13 AM »
ok, so what do i have to do to keep my car NHRA legal when i put a fuel cell and the battery in the trunk? my plan is to use a 20gal aluminum cell with the sump in the spare tire well. mount the pump in the well and drill a hole to run the fuel line under the car, and then mount the battery on the pass. side. any suggestions on the cell or battery box? i was thinking about one of the powdercoated cells from summit, but the batt. box is still open for discusion.
Scampin
Re: keep'n it legal
« Reply #1 on: February 08, 2007, 11:01:21 AM »
You will def. need to cut out the spare tire well to fit a 20gallon tank.  I had to with a 15gallon tank.
Soon to be: F-1 Procharged Scamp
kowski71400
Re: keep'n it legal
« Reply #2 on: February 08, 2007, 11:05:15 AM »
there's no way to mount the cell on the trunk floor with the sump in the well?
CudaDon65
Re: keep'n it legal
« Reply #3 on: February 08, 2007, 12:29:51 PM »
I have a 16 gal.cell with a sump in the well. I will need a fire wall to keep it NHRA legal.
kowski71400
Re: keep'n it legal
« Reply #4 on: February 08, 2007, 03:33:36 PM »
sorry, i think i should make myself a little more clear. i'm thinking of building some frame work to mount the cell to, so it will actually sit on the trunk floor and the cell sump will be "hanging" in the spare tire well. i will then mount the pump in the spare well to keep it out of harms way, since it is a street car.
Capt Jack
Re: keep'n it legal
« Reply #5 on: February 08, 2007, 03:37:48 PM »
the only issue I can see with that is if you had to work on the pump or lines and there was a full cell on top, it might be hard to get to.
dartracer
Strasburg CO.
Re: keep'n it legal
« Reply #6 on: February 08, 2007, 04:01:30 PM »
You will need a fire wall between the trunk and pass area, You will also need a cut off switch for the battery.  Dave
rharveysr
Re: keep'n it legal
« Reply #7 on: February 08, 2007, 04:18:25 PM »
The stock fuel tank on the Dart was leaking...so we removed it. Thought about putting a fuel cell in the truck but also want to move the battery back there too..Dont want to get too many things back there that could cause us issues since it is a street driven car.  Who makes a custom tank for under the car???  And since we are not going to need a electrical fuel pump the fuel cell would need to be plumb'd out the bottom of the tank...
Springs are going to be moved inboard so it will push the exhaust that much closer to the tank..
Thanks
Rick and Rickey Jr.
kowski71400
Re: keep'n it legal
« Reply #8 on: February 08, 2007, 04:48:43 PM »
are there any specs on the thickness of the firewall? should i use a sealed battery box with a vent?
Prodart
Re: keep'n it legal
« Reply #9 on: February 08, 2007, 05:05:19 PM »
If i remember right it's 26 gauge steel. brain fart Also the cell must vent to the exterior of car with tipover valve.
Mark
Scampin
Re: keep'n it legal
« Reply #10 on: February 08, 2007, 06:48:27 PM »
Gotcha.  I was going to do that also, but since I am gearing the Scamp more towards handling I wanted to keep the weight as low as possible.  I have seen a few people mount the fuel cell the way you are describing.  As long as you can keep the fuel cell far enough forward to leave room for the lines coming out it should work fine.
signet
Re: keep'n it legal
« Reply #11 on: February 08, 2007, 08:59:39 PM »
they say .024"steel or .032" aluminum as minimum thickness for the fire wall.
there are 2 other areas that allow vapours ect to get into the drivers compartment,normally they are covered with cardboard and thin fabric so they go unnoticed.
they are the C-pillar and the area were the rear window regulator is.
kowski71400
Re: keep'n it legal
« Reply #12 on: February 08, 2007, 10:02:07 PM »
thanks guys.
rharveysr
Re: keep'n it legal
« Reply #13 on: February 09, 2007, 09:44:51 AM »
Would removing the back seat back give enough access to cover it all up???  My son and I were talking about that last night.. The seat is out now so that we can open up the floor pan for the frame connectors..might be a good time to cover the stuff up..
Rick and Rickey Jr.
Blvedere
Re: keep'n it legal
« Reply #14 on: February 09, 2007, 08:01:13 PM »
I believe www.4secondsflat.com/ has a fuel cell that fits in the spare tire wheel well.
oldkimmer
Re: keep'n it legal
« Reply #15 on: February 10, 2007, 03:38:23 PM »
I believe to stay nhra legal the top of your fuel cell cannot be higher than the tops of your tires........Kim.............
Blvedere
Re: keep'n it legal
« Reply #16 on: February 10, 2007, 09:34:32 PM »
Was not aware of that, if thats the case I'm illegal.
duster-dan
71 Duster - 71 Demon, Wyoming,MI
Re: keep'n it legal
« Reply #17 on: February 10, 2007, 09:53:05 PM »
 agree I read that in the rule book, Its another one of those things do they check, or some tracks don't check.
