November 20, 2008, 10:25:00 PM
| | |-+  tubing notcher
Author Topic: tubing notcher  (Read 421 times)
tubing notcher
« on: February 09, 2007, 12:19:28 PM »
Has anyone used a tubing notcher from harbor freight to help with the installation of a roll cage?  I has thinking of buying it for.  I felt $40 was a good price, even if I only use it once for my roll cage.  What do you guys think?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42324
Re: tubing notcher
« Reply #1 on: February 09, 2007, 12:22:31 PM »
40 bucks sounds kinda cheap. I guess if you use quality holesaws with it, how bad could it be?
Midnight Special
GO HARD or GO HOME
midnightsplracin
Re: tubing notcher
« Reply #2 on: February 09, 2007, 01:03:35 PM »
40.00 FOR THE CUTTER AND 299.95 FOR THE DRILL PRESS.
Wichita Kansas Area
NHRA/SFI Tech Inspector
NHRA Division V
urchinhead
San Francisco, CA
Re: tubing notcher
« Reply #3 on: February 09, 2007, 01:19:17 PM »
Harbor Freight sells only the cheapest garbage made overseas. I would look for a used set-up before sending a penny to HF. Check out craigslist or Ebay. Just my humble opinion.
Re: tubing notcher
« Reply #4 on: February 09, 2007, 05:46:37 PM »
I have one of those elcheapo units.   I had to make a small brace for the back to hold it in my drill press.  Once braced properly it worked great ... you will need a deep hole saw to cut the notches in one pass.  I got the deep hole saw from S&W Race cars.  once  I had the deep hole saw it worked really well .. i have used it to install several cages in several cars ...
duster
Re: tubing notcher
« Reply #5 on: February 09, 2007, 05:57:48 PM »
This thread got me thinking about tubing notching. I have this book from Monster Garage called How to Fabricate Damn Near Anything. I first bought the welding book as a goof, but it turns out to be damn good. Anyway, I think there was a section in the fabrication book about using a plasma cutter to notch tubing. It looks like it worked pretty good, also, the plasma cutter is way more versatile if you had to spend money on a tool. I know it's way more than a tubing notcher, but if you plan on getting one someday, here's another use for it.
rharveysr
Re: tubing notcher
« Reply #6 on: February 09, 2007, 05:59:46 PM »
I know this may not be the same thing but here is my results with Harbor Freight..
1. Gear Press ....Piece of junk!  We used it to press out the bushings and ball joints on my 97 Dodge 2500..What a waste of money.
2. Mig welder car...PoJ..it nearly layed down twice..Took it back
3. Air die grinder...All I have to do is show it metal and it stops working..
4. Drill bits..I have to have my wife heat up the butter so that they will drill threw it
5. 2 speed polisher/sander..used it for 10 minutes and the switch shorted out
6. Floor jacks...great buy!
7. 4 wheel floor furniture dolly(3) works great!
Moral of this story.....buy only stuff from H.F. that you dont mind throwing away..
Re: tubing notcher
« Reply #7 on: February 09, 2007, 07:46:21 PM »
do you have any idea what a plasma cutter costs?I'm sure we all wish we had one,and i'd bet only a handfull of non pros here  have one.
Re: tubing notcher
« Reply #8 on: February 09, 2007, 08:01:03 PM »
Of course. Like I said, if you were going to possibly get one anyway, you could also notch tubing with it.
Re: tubing notcher
« Reply #9 on: February 09, 2007, 08:47:56 PM »
I got the notcher from Summit and it's great.  Don't need a drill press, just bolt it to a bench and use a 1/2" electric drill.  Works beautifully.
A13Dart
Minnesota
Re: tubing notcher
« Reply #10 on: February 09, 2007, 09:17:19 PM »
Dale Wilch here. It's the quality of the hole saws that count.
duster-dan
Re: tubing notcher
« Reply #11 on: February 09, 2007, 09:25:56 PM »
Evan
Fayetteville, Arkansas
bigjohncat
Re: tubing notcher
« Reply #12 on: February 09, 2007, 09:32:57 PM »
i know this is a dumb question, but i have never built a cage. what do you use the tubing notcher for? thanks,      -Evan
Re: tubing notcher
« Reply #13 on: February 09, 2007, 09:47:57 PM »
To fishmouth the ends of the tubes where they connect to other tubes. It's how you fit the door bars to the main hoop, for example. All joints have to be super tight for good welding.
Re: tubing notcher
« Reply #14 on: February 09, 2007, 09:48:03 PM »
No kidding - Dale Wilch from RPM Catalog?
And he's right - buy some Lenox hole saws and you'll be really happy.
Re: tubing notcher
« Reply #15 on: February 09, 2007, 09:49:42 PM »
Thanks guys.  I know everyone has their preference.  But for something I may only use once, there is no sense in buying an expensive notcher.  Harbor freight it is.  THANKS
A13Dart
Minnesota
Re: tubing notcher
« Reply #16 on: February 09, 2007, 10:11:19 PM »
Yup, the ol joint jigger. Had it for many years.
vitamindart
Re: tubing notcher
« Reply #17 on: February 09, 2007, 10:16:59 PM »
my buddie has one works fine , like everyone else said just buy some good holes saws and use oil just make shure to clean the oil off well
i actually bought a different notcher and the only difference was i paid more and it had a bracket on the back to make it easier to put in the drill press to bad i don't have a press just a hand drill
Re: tubing notcher
« Reply #18 on: February 10, 2007, 12:20:47 AM »
WHat are good hole saws?  hows much should I pay for one to make it a good one?
Re: tubing notcher
« Reply #19 on: February 10, 2007, 12:28:23 AM »
Like was said earlier, just get Lenox. Those are great. I haven't bought any for a while, but I know they're not exactly cheap. Don't be misled into inferior ones by a lower cost. Lenox holesaws will make that 40 dollar tool operate nicely.
Re: tubing notcher
« Reply #20 on: February 10, 2007, 08:24:37 AM »
Call S&W Race cars 1-800-523-3353 tell em you want a deep hole saw for 1 5/8 tubing ... they will put it in a box and send it to you
