July 23, 2008, 06:17:58 PM
| | |-+  Wiring Harness Question Guru's come here please!
Author Topic: Wiring Harness Question Guru's come here please!  (Read 370 times)
demon340v
« on: February 15, 2007, 03:51:29 PM »
OK guys i got a question, is there a std guage wire for the wiring harness?
I'm goign to attempt to make my own wiring harness and well  is there any specfic size wire i'm supposed to use? the connectors i think i got pretty much covered. i just woudl liek to knwo the guage wire for teh light harness, tail lamps engine harness so on and so forth.
Any help is appreciated
moparrr07
working on custom console
Re: Wiring Harness Question Guru's come here please!
« Reply #1 on: February 15, 2007, 05:39:34 PM »
from what i see in diagrams it says that early cars have 18 gauge and later cars have 20 gauge, im not sure what the cut-off year is but i think 69-70 is the change, i put in 18 gauge in my 72 because thats what auto meter recommended
brakes, 11 3/4
60-0: 105 ft.
cornering gs: estimate: .90
50% custom interior
« Reply #2 on: February 15, 2007, 06:27:17 PM »
Each circuit is different. You really need to look at a factory wiring diagram. The aftermarket ones don't have guage sizes.
demon340v
« Reply #3 on: February 15, 2007, 06:43:25 PM »
My Dad lucked out and hsi wiring diagram shows the guage for his 70 Runner   Seeing my Demon is a 71 i picked up a new wiring diragm since i lost my other one and i can't really recall the guage wire being on there.
Jim do you knwo of any place i can look for this?
Dallas, TX
« Reply #4 on: February 15, 2007, 08:01:59 PM »
It really depends entirely on how much power you run through (current/amperage) your wire.
Here is a rule of thumb I use:
20ga -   5A fuse - temp sensors, fuel injectors (rarely used in old cars)
18ga - 7.5A fuse - small stuff, like guage lights, relay triggers, sensors, etc
16ga - 10A fuse - Car radio, turn signals, dome lights
14ga - 15A fuse - Ignition, coil, cig lighter or accy tap, brake lights, speaker wire
12ga - 20A fuse - High power ignition systems, small speaker amps, headlights,
10ga - 30A fuse - single speed electric fans, better for headlights, relay power feeds.
8ga  -  60A fuse - High power amps, dual speed Viper fan
2ga -   Battery Cables.
Allentown, PA
« Reply #5 on: February 15, 2007, 08:04:41 PM »
 agree
Flyboy has it covered ....
demon340v
« Reply #6 on: February 16, 2007, 11:26:05 AM »
Thanks guys for the help
« Reply #7 on: February 16, 2007, 11:32:59 AM »
You can use the wiring diagram for the Road Runner. The wire sizes would have been the same.
moparrr07
« Reply #8 on: February 16, 2007, 12:55:31 PM »
what i stated was from Chrysler service manuals Wink- autometer recommends 18 gauge
brakes, 11 3/4
60-0: 105 ft.
50% custom interior
74swinger
« Reply #9 on: February 23, 2007, 09:11:27 PM »
I have the factory manual for a '74 Swinger and there is very little 20 gauge wiring (some for the instrument cluster lights, seat belt interlock crap, other misc lamps in the passenger compartment).  Each circuit should be considered separately - that's why almost every possible gauge of wire is used in every car.  By the way, nothing stopping you from upgrading from termination to termination if you want.
Dallas, TX
« Reply #10 on: February 24, 2007, 09:28:16 AM »
On modern cars, some wire have very little current running through them, most ase just sensors and signals. On a new 300C, there is over 400lbs of wire in the car, so they teld to use the smallest wire practical to save weight, and the cost of copper. Unless you are building a lightweight race car where weight is an issue, there is no reason to go with wire smaller than 18ga.
