August 28, 2008, 01:55:19 PM
| | |-+  dipping or blasting??
Author Topic: dipping or blasting??  (Read 324 times)
vitamindart
« on: February 15, 2007, 10:07:14 PM »
so i've ben working on my new project a 47 plymouth club coupe the body needs some work , i want to get it cleaned but i'm not shure if i should have it blasted or dipped .. i'm leaning to dipping i had my dart blasted but when i replaced the bad spots in the floors and opened the frame rails   yuck!! rust and it still leaves puddles of sand to this day . and i figure dipping will clean between the panels but i was quoted 800 to 1100 to dip just the shell no doors or trunk
urchinhead
San Francisco, CA
Re: dipping or blasting??
« Reply #1 on: February 15, 2007, 10:09:49 PM »
I believe you already answered your own question. Better work some overtime!  duster
dustertogo
« Reply #2 on: February 15, 2007, 11:43:54 PM »
 The problem with dipping is that is removes all the paint and primer from areas you can't get to . So there will be bare metal that will rust in all the nooks and crannys. If you get it dipped, get it galvinized(spelling??)as well , then you should be ok.  Troy
74swinger
« Reply #3 on: February 23, 2007, 09:00:38 PM »
.....galvanized.....sorry, my wife is a grammer nazi and it is rubbing off (rub harder, baby, harder Smiley)
If this place can acid dip, they must be able to do a primer or sealer dip as well.  Check it out.  Liquid can go where eyes can never go.  The rust will be visible after the hole is blown out............  Frustrated
mopardad
PERRY FAMILY RACING
« Reply #4 on: February 23, 2007, 09:17:14 PM »
Ive seen some beautiful work come out of an acid bath, but in order to get ALL the acid from the hidden spots, you have to dismantle every little item and wash it down really well with water. IMO, a good media blast( walnut shells or glass media) is the best bet. A shop vac makes for faster cleanup and the media doesnt cause rust if you miss some.
Things go better with a BIG BLOCK!
jamesdart
« Reply #5 on: February 24, 2007, 09:22:09 AM »
id have it blasted, but acid dipping isnt even done here in nj. i think.
