October 12, 2008, 10:33:44 PM
| | |-+  started on the subframe connectors
Author Topic: started on the subframe connectors  (Read 837 times)
mopowers
« on: February 17, 2007, 01:41:20 AM »
I started on the subframe connectors today and thought I'd share some pictures.  I decided to run the 2 x 3 .125 wall tube with the 3" portion verticle just to make it hard on myself.  I drilled some holes on the part that slips over the rear framerail so I can get some plug welds in.  I'm not sure if that will help any.  I'm also thinking of adding a u-shaped portion in front to sort of incase the crossmember where it welds to in front.  This will probably be overkill, but I'm having fun cutting and welding.  It's my first time doing this stuff.  Hopefully I'll have pictures of the install tomorrow for you guys to see.
2006 Dakota
Long Island, NY
Re: started on the subframe connectors
« Reply #1 on: February 17, 2007, 01:43:09 AM »
Very nice work for a first attempt.
abqdart
72 Swinger 394/727/8.75
« Reply #2 on: February 17, 2007, 01:45:54 AM »
 agree.....good job, seems well thought out too. I would rather have a little overkill than not enough.
Rio Rancho N.M 87144
mopowers
« Reply #3 on: February 17, 2007, 04:51:27 PM »
Thanks guys.  I decided to add a little more overkill strength to where they mount in the front.  I haven't welded them in yet, but here is what they look like under the car.  Now I just have to figure out what I'm going to do for my parking brake cable.
2006 Dakota
abqdart
« Reply #4 on: February 17, 2007, 08:08:59 PM »
OUTSTANDING!! good work
Scampin
« Reply #5 on: February 17, 2007, 08:25:28 PM »
Wow!  That looks awesome!
Soon to be: F-1 Procharged Scamp
ski
« Reply #6 on: February 17, 2007, 08:43:12 PM »
Nice work!
signet
« Reply #7 on: February 17, 2007, 09:08:16 PM »
looks real good.
thanks
i like those saw horse legs too.
MyCreation68
« Reply #8 on: February 17, 2007, 09:35:01 PM »
Lol hope you don't mind but I'm "borrowing" the pics for examples when I go and do mine  taunt
Good work
-46 Fargo
fasttcars
« Reply #9 on: February 17, 2007, 09:38:07 PM »
nice job!..i like it...
70 Dustpan
Sacramento CA.
« Reply #10 on: February 17, 2007, 09:39:23 PM »
Nice work, they look good.
Hey, I'm a God again!
Birdius Rapidus
« Reply #11 on: February 17, 2007, 10:01:34 PM »
Great Job.
Ciscodog
« Reply #12 on: February 18, 2007, 09:31:16 AM »
Nice job dude!
Carter
mopardude318
« Reply #13 on: February 18, 2007, 01:39:29 PM »
those look awesome! nice work! Smiley
1970 Dodge Dart, 408 sb, eddy heads, 4 spd, alterktion, 8 3/4
Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax. - David Charles Gedraitis
Allentown, PA
« Reply #14 on: February 18, 2007, 04:09:45 PM »
Nice looking work  ...
bbd sign
duster
mopowers
« Reply #15 on: February 18, 2007, 07:36:39 PM »
Thanks guys.  I'm trying to figure out what I'm going to do for an e-brake.  Do you think I can just weld a piece of angle iron on the bottom of the drivers side subframe connector and drill the appropriate size hole for it?  That way the cable would run under the connector.  Or should I just use it's stock location and drill a hole in the subframe connector for the cable to go through?  Any ideas?
2006 Dakota
Allentown, PA
« Reply #16 on: February 18, 2007, 08:11:51 PM »
 there is usually enough room to dril a new hole along the old one so it will be outside the frame connector ... or if the only part of of the frame connector that interfers is the front flange then drill that puppy out and letr' rip
duster
Ciscodog
« Reply #17 on: February 19, 2007, 10:44:15 AM »
I ran my cable under the connector.  Just cut a piece of round tube in half and tack it to the bottom to capture the cable where you want it.
dangerdawg
« Reply #18 on: February 19, 2007, 07:18:26 PM »
good job! makes mine look bad.
urchinhead
San Francisco, CA
« Reply #19 on: February 19, 2007, 07:25:16 PM »
Wow! Those pictures make we want to take the welder out!
dusterman70
« Reply #20 on: February 22, 2007, 12:53:52 AM »
  agree that looks really nice! Cheers
WRAITH
« Reply #21 on: March 05, 2007, 04:06:03 PM »
Soooo,... now I think I'll hafta turn mine 90 Degrees. Thanx buddy! Nice work by the way.
WRAITH
'67 Dart GT
Low Deck 400
Hemi 4 Speed
8 3/4"
HemiDoug
« Reply #22 on: March 06, 2007, 11:20:55 PM »
For the e-brake, I made a new set of holes farther outboard and above the flange on the frame connector. The hole is bigger on the front side of the crossmember than the rear, and the rear hole has to be the right size to capture the e-brake bushing. Just duplicate the hole sizes, and make sure they are in line! Great looking installation!
